De-esser in DP 7 ?
Gone To Lunch
De-esser in DP 7 ?
Post by Gone To Lunch »
Simply, is there a De-esser in DP 7 ?
http://gonetolunchmusic.com/
Current sex toys : DP 11.32, Mac M1 Studio OS 13.6.3 64 gb Motu M4. Sounds by VSL, Addictive Drums 2, Native Instruments, Orange Tree, Bolder Sounds. Plug-ins by PSP, VSL MIR Pro 3D, 2CAudio, Waves & Lexicon. Scores by Dorico Pro 5.4.
kassonica
Re: De-esser in DP 7 ?
Post by kassonica »
Not really :(
However there are some presets in the MW compressor, that may help you.
rodger1811
Post by rodger1811 »
Before I got a good De-Esser, I used EQ a lot of times. I would sweep and notch it out or setup a sidechain with a compressor and tame it that way. Now I use the Universal Audio Precision De-Esser and I love it! :)
Mid 2012 Mac Pro 12 Core 2.4GHz, 24G RAM, OSX 10.8.2, DP 8.01
4x2 TB Hard Drives
APOGEE Symphony
MOTU 2408 mk3
MOTU HD192/Black Lion Modified
MOTU 24I/Ox2
MOTU MIDI Timepiece
Universal Audio UAD-2 Quad x 2
Universal Audio (Entire Plugin Library)
Waves Mercury+ Studio Classics
Tons of other goodies; to many to mention here
jlaudon
Post by jlaudon »
I've found that automating the volume on the sss is the most natural result, but it takes time (I also have the Waves and UAD de-essers).
waxman
Post by waxman »
UAD Precision De-Esser +1
waxman
towerproductions
Post by towerproductions »
UAD De-Esser but I also do the volume automation as well for results.
DP11.1, Mac Pro 3.33 / 12-core, 96GB RAM, Mac OS 10.14.6
2 MOTU 2408 mk3s Black Lion mod, , UA Apollo Quad, UAD 2 Octo PCIe,
a bunch of EW Play,Opus, Spitfire, Sine,UVI, Kontakt Komplete Ultimate, VE Pro 7, Falcon, DSP Quattro, AmpliTube 5,and way too many others.
Phil O
Post by Phil O »
If all you have is DP plugs you can make a de-esser with the Dynamics plug. Duplicate the vocal track you want to de-ess and set it's output to a buss. Use that buss as the side-chain input for the Dynamics plug (placed on the original vocal track). Now EQ the duplicated track so that just the esses come through. You're now sending those esses to the side chain of the Dynamics plug. As an alternative to duplicating the vocal track, you could also route the signal through an aux track (with appropriate EQ) using a send.
dpdan
Post by dpdan »
Remember that esses usually are not dynamic like vocal loudness.
Regardless of how loud or soft the singer sings,... their esses are usually the same volume.
Dan
Phil O
Post by Phil O »
dpdan wrote:Remember that esses usually are not dynamic like vocal loudness.
Dan
I'm missing your point on this, Dan. Could you elaborate? I get the feeling this may be important to this discussion, even if only slightly off topic.
Phil O
Post by Phil O »
PS. I tried the technique that I described previously with the Rocket compressor from Stillwell. Works great!
dpdan
Post by dpdan »
Hi Phil,
If you have a solution that works that's great.
The thing that I wanted to point out, (if one doesn't have a specific de-esser plugin) is drawing a sharp "V" in the soundbite's EQ gain automation which will quickly cut the gain of an EQ set with a very narrow bandwidth..., this will probably yield better results. And assuming the frequency is dead on for the es' pitch, this will be more time consuming, but will better.
Once you draw a nice V that works well, you can copy it and paste it over all the esses.
It is good to realize that the "S" sound produced by a vocalist is usually the same volume regardless of the notes being sung. So, if this (home-made) de-esser was post volume automation, it would not be as effective.
I know this kind of anal editing is not for sissies,,, but the results are great, it just depends on how perfect one wants it to be. :)
just my 2 cents :)
Dan
Timeline
Post by Timeline »
In the Waves renaissance plugs their Deesser I find blows away UA or anything I can manufacture out of a multi-band DP plug but it's not cheap.
Phil O
Post by Phil O »
Come back, GTL. It's ok, we're always like this. I guess the answer to your original question is, "No." But there seems to be an endless supply of options for you. Let us know what kind of work you're doing and we'll probably throw even more ideas at you. :D If you're on a tight budget, the Stillwell stuff is great bang for the buck, but I don't think he has a de-esser. Maybe if we put bug in Scott's ear, he'll come up with one. Also check out the free plug-in/VI sticky. There might be something there.
waxman
Post by waxman »
Timeline wrote:In the Waves renaissance plugs their Deesser I find blows away UA or anything I can manufacture out of a multi-band DP plug but it's not cheap.
I use both Waves and UAD... I prefer the UAD
waxman
Phil O
Post by Phil O »
dpdan wrote:I know this kind of anal editing is not for sissies,,, but the results are great, it just depends on how perfect one wants it to be. :)
just my 2 cents :)
Dan
But, you are right, Dan. I wouldn't call fussy editing "anal," just good engineering. Sometimes to get really good results there are simply no shortcuts. But of course, when cost is a concern the shortcuts become necessary. A de-esser is one of those items I usually put in the "shortcut" category. I totally agree with you that careful automation usually yields better results for esses and also pops.
