No Control Surface option ???? [RESOLVED]
BLISS
Post by BLISS »
In DP6, when I go to > SETUP > CONTROL SURFACE> then my option to ADD (the + symbol)
I have no options ? I do see my Control Surface folder in the Applications area, so why dont I have the option to sync my DIGITAL MIXER, Im confused. Need a bit of help.
carrythebanner
Re: No Control Surface option ????
Post by carrythebanner »
Which mixer are you using, and which control surface protocol are you hoping to use (HUI, Mackie Control, etc.)?
BLISS
Post by BLISS »
Mixer I am using: DM24 via MIDI, I would like to use HUI mode
The mixer allows me to set in OPEN MODE, so when I hit play in DP6, the FRAMES 00:00:00:00 begin to move simultaneously, but...
If I press PLAY on the DM24, set SYNC in DP6 to MIDI Ch 6 (which it is on) and I go to Control Surface and try to add (+) Nothing comes up to even add????
I've checked the settings in the DP6 and it's all there
BLISS
Post by BLISS »
Sorry, this is all connected via the MOTU 128 EXPRESS (USB) 8x8
DM-24 I/O to EXPRESS 128 channels 6 I/O and back into the DM24
carrythebanner
Do you see HUI.bundle, or any other plug-ins, in /Library/Audio/Plug-ins/MOTU Control Surface?
BLISS
Post by BLISS »
Yes, I do, I see: CueMixMackieSurfaces.bundle, HUI.bundle & MackieControl.bundle
carrythebanner
To be clear, when you open Setup menu > Control Surface Setup and press the "+" button, you see a Driver menu appear, correct? And that Driver menu is empty when you click on it?
BLISS
Post by BLISS »
When I click on the (+) button, ABSOLUTELY NOTHING COMES UP,
I know what you are talking about, I can see it in my manual, but NOTHING COMES UP, to where I can put (HUI-1-8) and so forth and so forth
That's my dilemma
Setup menu > Control Surface Setup and press the "+" button, you see a Driver menu appear, correct ? (NOTHING APPEARS FOR ME THERE, I keep hitting the "+" button over and over and over and nothing.
carrythebanner
Weird. Something funky is definitely going on. I'd try to get on the phone with MOTU.
BLISS
Post by BLISS »
I know :shock: right
I've gone over this and over this, removing, re-adding files, shutting down, turning back on, and it's weird, but no love lost.
It's not totally hindering me from being the creative producer that I am, ((but it will nag the hell outta me to try and figure it out))
BLISS
Post by BLISS »
Carrythebanner----- I want to just thank you for talking with me over this issue.
I got it working, just opened up a new DP session and vwala, it was there. I had been trying a DP set up that I use with my clients. I kept trying the same one over and over, so... I said, open up a NEW one, and BAM. My DM-24 now can control DP6 via: PLAY, STOP, FF, RW and REC.
And somehow when I went BACK to my client DP set up, THEN the icon for Control Surface was there miraculously ?????
But it's working now, and thank you for discussing this with me, I stayed on my brain and I didn't give up, (rather didn't want to stop till I got it) I knew it was possible, just couldn't figure it out- at the moment. :D :D :D :D :D :D
carrythebanner
Sure, you're welcome. Glad to hear that my non-specific help somehow lead you to a resolution, unexplainable or otherwise.
"Any sufficiently advanced technology is indistinguishable from magic."
- Arthur C. Clarke's Third Law
I'll mark this thread resolved.
