Best way to speed up a song before mastering... ?
HooVoo
Post by HooVoo »
I just mixed a track at 75 bpm and i need it to be 77-78bpm.
Which is the best way to time stretch it a bit without ANY artifacts?
Thanks...
Mac Pro 8 Core, 9GB Ram, Prism Orpheus, DP7, Logic Studio, Reason+Record, All Spectrasonics, NI Komplete, etc etc
glamacchia
Re: Best way to speed up a song before mastering... ?
Post by glamacchia »
I prefer to just raise the house clock rate and dump it again ( I don't mix in the box though - real time multi track play back from the DAW through a desk to the 2 track mastering/ mix down station.
If the pitch positively CAN'T be raised when you speed up the tempo then you have to remix it... I assume you did this via MIDI tracks and a DAW, so change your tempo - MIDI will not be an issue but audio tracks can get confusing if they are pieces that start here and end there, then a punch here out there..... merge and make them ALL the same length / start time then let your DAW chew on them and see how they sound sped up. If it flies, you're done, if it Alvin Chipmunks, re-cut it
Commadore 64, Sony MXP3036, DEC PDP11's, 1961 Rupert Neve tube / Valve based (@)(@) Console, Telefunken U47, Urei, Studer, MCI and Harris TAPE . . . and 2 turntables(.Y.) and a microphone
Dwetmaster
Post by Dwetmaster »
Pitch'n Time...
bongo_x
Post by bongo_x »
I would talk to the mastering guy, they do this all the time.
There's no way I'd use any timestretching. I'd go to tape and back or do it like glammachia said.
You could also edit the whole thing to a faster tempo, chop it up and move all the pieces to the new tempo. I've done this a lot, it's time consuming but can sound really good.
bb
zed
Post by zed »
HooVoo wrote:Which is the best way to time stretch it a bit without ANY artifacts?
More ideas here...
http://www.motunation.com/forum/viewtop ... po#p323243
bongo_x
Post by bongo_x »
More ideas here...
I felt like I was repeating myself! My memory is so crappy that I'm never sure.
At least I didn't contradict myself. Close one.
bb
zed
Post by zed »
bongo_x wrote:I felt like I was repeating myself! My memory is so crappy that I'm never sure.
Ha!! I hadn't noticed that. Your responses were almost the same!
Pretty difficult to contradict yourself when you are this clear on your response to a topic! ;-)
HooVoo
Post by HooVoo »
Thank you guys :)
ps. tried them all... the best was---> Record by Propellerhead, believe it or not!
zed
Post by zed »
HooVoo wrote:ps. tried them all... the best was---> Record by Propellerhead, believe it or not!
Not sure how helpful this statement is. What exactly did you try? What else was included in the group "all"? I'm perfectly willing to accept the possibility that Propellerhead software does some great time stretching, but unless we know what other products or methods you tried then I'm not going to be rushing out to buy Record. Please elaborate if you have the time. :-)
