MODEL 12 crashing
straysean
MODEL 12 crashing
Post by straysean »
Hello,
can anyone help me. in DP6 & now DP7 the model12 sound just cuts out after 10 minutes. closing the model12 window starts the sound again but cuts out shortly after. a combination of stop/starting & closing and opening the window gets the sound going again. all other synths & effects are fine. any ideas?
kassonica
Re: MODEL 12 crashing
Post by kassonica »
Must be the pre rendering day, or something, but turn off pre rendering and see if that helps......
Phil O
Post by Phil O »
Yes, kassonica is right. I had this problem and the solution was to always run in real time. I've had no problems since doing this. :)
seanarorke
Post by seanarorke »
thanks for the replys. yeah, turning pre gen off seems to work but this is a new feature that is one of the reasons to upgrade. got NI battery 3 now which is much better, so not been using model 12. anyway, life goes on eh?
Frodo
Post by Frodo »
If I could **gently** suggest that we be careful with the use of the word "crash" in all its forms and to save that description specifically for apps which quit without being manually prompted to do so.
Happily, this situation was a fairly easy fix.
