please help!! to do with the ultralte mk3
freesian
Post by freesian »
hi there
i am in hope of some answers for a few simple questions.
i am currently using the native instruments audio kontrol external sound card with vista 32bit!! i need a new sound card as the audio kontrol is not built for zero latency real time performance.
will the ultralite mk3 allow me to listen to the cue mix on the headphones and have the main mix going out to the speakers??? the audio kontrol did this as its designed as a dj solution.
also will this sound card give me actual zero latency with both a MIDI keyboard and a guitar without comprimising the playback quality.
this is all i need to know. i need to buy something soon that can do the headphone thing and give me zero latency MIDI and audio realtime playback without comprimising the quality of the playback.
help would be much appreciated¬¬!!!! is the ultralite mk3 what i need?????????
thanks
danel
mcoyles
Re: please help!! to do with the ultralte mk3
Post by mcoyles »
Should work fine for this purpose. Cuemix allows realtime monitoring of audio inputs... and even without using cuemix, latency is only 6 > 12ms which is unnoticeable for all intents and purposes.
L8rs...
Marci
