Thanks MOTU, the 7.02 update is very welcome. I have recently bought Celemony Melodyne, and some of the advertised functions don't work when used as a plugin in DP 7. The .02 update does not fix them. Hopefully an update from Celemony is forthcoming.TechSupport wrote:A Digital Performer 7.02 maintenance update is now available, with enhanced Snow Leopard compatibility and other improvements. A related DP 6.03 maintenance update is also available, with and Countoff enhancements and enhanced Snow Leopard compatibility.
Regards,
MOTU Tech Support
Digital Performer 7.02 and 6.03 maintenance updates
Re: Digital Performer 7.02 and 6.03 maintenance updates
iMac 2019, 40 GB RAM
MacBook Pro, 16GB, OSX 10.11
DP10, Studio One, PT, Logic X, Sibelius, Live, Reason
Apogee Duet, Apogee Ensemble
You really need to contact Celemony support about this. It is their responsibility to fix it, not MOTU's. Please list what isn't workingritzybiz wrote:Thanks MOTU, the 7.02 update is very welcome. I have recently bought Celemony Melodyne, and some of the advertised functions don't work when used as a plugin in DP 7. The .02 update does not fix them. Hopefully an update from Celemony is forthcoming.TechSupport wrote:A Digital Performer 7.02 maintenance update is now available, with enhanced Snow Leopard compatibility and other improvements. A related DP 6.03 maintenance update is also available, with and Countoff enhancements and enhanced Snow Leopard compatibility.
Regards,
MOTU Tech Support
on your system, and the exact system you have, when sending them a tech support request. Their tech support e-mail is:
support@celemony.com
It would also be helpful to all of us here if you posted a list of things
in Melodyne Editor that aren't working for you.
http://www.davepolich.com
Can you please post the Melodyne problems you are having on the following thread:ritzybiz wrote:I have recently bought Celemony Melodyne, and some of the advertised functions don't work when used as a plugin in DP 7. The .02 update does not fix them. Hopefully an update from Celemony is forthcoming.
http://www.motunation.com/forum/viewtop ... 80&start=0
Yes indeed... link to the Celemony thread is included above.David Polich wrote:You really need to contact Celemony support about this...
Is it just me or does 7.02 have automation lines built in the SE? Yay!
MacBook Pro 2021 (M1 Ultra) with 64 gigs RAM. DP 11.23
I have already contacted Celemony, and they have virtually "passed the buck" back to MOTU.David Polich wrote:
By the way, I did list the problems on another thread "Melodyne Editor Released", which you have also contributed to.
I do, however, thank you for your advice.
What's this mean?jlaudon wrote:Is it just me or does 7.02 have automation lines built in the SE? Yay!
The dotted lines for volume (at 0), pan (at Center), etc are already in the SE, and when you turn on automation, they become solid lines ready to automate right away.
- corbo-billy
It was like this before .
And this is the first time I see a MOTU Application upgradeable through two versions simultaneously .
Imac M4 24" under Sequoia 15.3.1 & Kontakt 8.2. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.34 _
That's not what I get. I still have to create an automation event before I get an editable line as. Nor do I see the dialogue box that asks which plug in set I want to use, that someone mentioned. I've confirmed I am looking at 7.02. I can "see" no differences at all between this and 7.01jlaudon wrote:The dotted lines for volume (at 0), pan (at Center), etc are already in the SE, and when you turn on automation, they become solid lines ready to automate right away.
I think you're right - for some reason the specific projectI'm working showed all dotted lines, which is actually a hassle becauase when you turn on automation, everything snaps to that position which screws up a rough mix (with no automation).
I'm finding pitch correction is a bit flaky in 7.02 (some soundbites don't show any pitch, some do). I went back to 7.01 for now.
Hmmmmm. I've been finding some stuff like that in 7.01, so I'm not sure it is really different in 7.02. You might want to try just restarting and trying 7.02 again. It may just take an opening or two before it settles down. The first time I opened it I had no keyboard commands working so I just quit and restarted (without being so hasty to press the "Okay" dialog boxes) and now it is working just fine.jlaudon wrote:I'm finding pitch correction is a bit flaky in 7.02 (some soundbites don't show any pitch, some do). I went back to 7.01 for now.
- Tonio Ruiz
this same thing happen to me on 6.02, I hoped that was fixed on 7 versionszed wrote:Hmmmmm. I've been finding some stuff like that in 7.01, so I'm not sure it is really different in 7.02. You might want to try just restarting and trying 7.02 again. It may just take an opening or two before it settles down. The first time I opened it I had no keyboard commands working so I just quit and restarted (without being so hasty to press the "Okay" dialog boxes) and now it is working just fine.jlaudon wrote:I'm finding pitch correction is a bit flaky in 7.02 (some soundbites don't show any pitch, some do). I went back to 7.01 for now.
Enjoy Life!!!!
http://www.trmixroom.com" onclick="window.open(this.href);return false;
http://www.myspace.com/tonioruiz" onclick="window.open(this.href);return false;
Mac Pro quad 2.66 5gig RAM/ MOTU HD192 Core System 24ch / MOTU 1224 / DP7.2 / MOTU Micro Express / Waves CLA bundle / Melodyne / ProTools LE 8.03/ Analog Mixer / Analog Outboard
- Tonio Ruiz
hey, do anyone knows if I can use DP7 on a G5 single 1.8, 3gb ram???
I die to upgrade to 7 but I still have this single processor G5
thanx for the info
thanx for the info
Enjoy Life!!!!
MOTU wrote:The minimum system requirements for Digital Performer 7 are as follows:
Mac OS X v10.4.7 or later (including Mac OS X v10.6)
PowerPC G4 1 GHz or faster CPU (including PPC G5 CPUs and all Intel processor Macs)
1 GB RAM
1024 x 768 display resolution
CD-ROM drive for installation and authorization
We recommend a system with the following components:
multi-processor or multi-core PowerMac G5 or Intel processor Mac
2 GB RAM or more
1280 x 1024 or larger display resolution
does iPerformer and Ampidood mods work with 7.02???
waxman
