Nomad Factory Plugin Offer: The Integral Studio Upgrade
- Radiogal
Re: Nomad Factory Plugin Offer: The Integral Studio Upgrade
I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?
Keep us posted! As soon as I finish this project it might be time.
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
- tommymandel
Up until I upgraded to Leopard on my DualCore 2.3 G5, I was running Tiger, 10.4.11, and for a while I was running the Nomad Demos. They worked great. But oh, that was back before DP7, it was DP 6.0 and 6.01 and 6.02, so sorry, can't tell you about the exact combination you are talking about.Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?
- corbo-billy
Problem still not solved ! Can anyone help me ?
http://www.motunation.com/forum/viewtop ... ad+factory
My avatar cause there a lack of response.
- burn em
Dual 2ghz(PCI version) / 10.4.11 / DP 7.02 running a treat here. Very happy indeed!Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?
They seem to be very efficient plugs in 7.02, not processor hogs at all!
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
- davedempsey
burn em,burn em wrote:Dual 2ghz(PCI version) / 10.4.11 / DP 7.02 running a treat here. Very happy indeed!Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?![]()
They seem to be very efficient plugs in 7.02, not processor hogs at all!Unlike some PSP plugs...
How'd you get DP 7.02 before the rest of us?
Lots of stuff and a recently acquired ability to stop buying
- burn em
Ahhh... ummm... I have 7 too... Yeah DP7, it's made by MOTU yes?davedempsey wrote:burn em,burn em wrote:Dual 2ghz(PCI version) / 10.4.11 / DP 7.02 running a treat here. Very happy indeed!Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?![]()
Don't want to go OT, but since I nearly missed the Integral upgrade due to a site problem, I wanted to chime in to say how great Peter is to have sorted it all out for me. Don't Crack has been (and continues to be) uncannily helpful.
<cue: rounds of resounding applause>
- Shooshie
Hi Radiogal. Did you end up getting the Nomad plugs? If so, are they working fine with your combination? I'm curious to know; no real reason since I don't use that combination, but I'm just curious.Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?
Best wishes,
- tommymandel
Re: Nomad Factory - Upgrades ?
Shooshie, I bought, but the Presets you mention don't show up in DP. I did locate them in Application Support, should I move them to Audio/Plugins/Presets/Nomad - where the few that I made up reside? Thanks.Shooshie wrote:
Also, your presets are excellent. It would literally take me years to get as far as these presets go. This is perhaps the best set of presets I've ever had in plugins of any type. They're not only great for actual use, but they're educational as well. I've learned a lot about audio processing just from observing the presets.
Also, a little weirdly, I was never asked for my Response Code, although the website says I'm authorized, and has the correct 2 HD count (for my Laptom and G5 Tomer).
EDIT (11/20):
It seems my own created presets are in
root/Library/audio/plugins/presets/nomad factory,
but the factory ones are in
root/Library/application support/nomad factory/plugin settings
They both show up, but in 2 different areas of the (excellent btw) Nomad plugin windows.
No DP7 here yet, but DP 6 w/Nomads is fine on that configuration for me. Probably shouldn't be a problem.Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?
Success is just one more plugin away! And happiness is as close as your next upgrade.
- Radiogal
Hi Shooschie, Didn´t make the jump to DP 7 yet. Have some client studio sessions booked during the next coming weeks. So I´m still on rock steady DP 5.13 untill I dare the jump and might scratch my kneeShooshie wrote:Hi Radiogal. Did you end up getting the Nomad plugs? If so, are they working fine with your combination? I'm curious to know; no real reason since I don't use that combination, but I'm just curious.Radiogal wrote:I´m about to jump from DP 5.13 and install DP7. Anyone on a MAC G5 PPC dual, OSX 10.4.11, running DP 7 and the Nomad plugs? Is it all running successfully?
Best wishes,
- Renaissance Man
Having used the Nomad plugs for about a year now, I'm very glad I got on the Integral Studio Pack upgrade bandwagon. The more I use these plugs, the more I like them.
Mac Pro Mid 2012 12-core 3.46GHz, 128GB RAM, Mojave, DP11, Waves Mercury & SSL 4000, VocAlign Project 3, Melodyne 5, EastWest Quantum Leap Pianos & Voices of Soul, Nomad Factory Integral Studio Pack, Slate Digital VCC, RC Tube & Trigger, & lots more plug-ins, MOTU PCIe 424, 3-2408Mk3's, 24io, MTP AV USB, Apogee AD-16X's & Big Ben, CraneSong HEDD 192, ATC monitors, tons of outboard gear & microphones, MIDI/keyboard rig, house drums & tuned percussion
www.nrpstudio.com
www.nrpstudio.com
+1
If anyone missed this deal, please PM me.
Thanks,
Dope
Thanks,
Dope
