User survey
Re: User survey
DP 7.01 and 6.02 with OS 10.5.8
DP 7.01 with OS 10.6.1
Both working fine.
Both working fine.
- kassonica
Re: User survey
DP7.01 with 10.6.1. Rocking
DP6.02 with 10.5.7 Not as stable or as fast but pretty good.
I mainly use Top one now
Re: User survey
DP 6.02 on SL.
Every time I start to get ready to up to DP7, another killer group buy pops up. It's a conspiracy against my wallet.
- KEVORKIAN
Re: User survey
DP 7.0.1 on OS 10.6.1
Re: User survey
DP 7.01 with Snow Leopard 10.6.1.
- Albert Bacardit
Re: User survey
Dp 7.01 with 10.4.11
MacBook Pro 2.2, 16G RAM, OS 10.12.5, DP 9.5, Ultralite, MC Mix, A7s, Guitars, Keyboards, Amps, VIs and Plugins.
Re: User survey
DP 7.01
OS 10.6.1 here. Waiting for 10.6.2 for some other things. Current setup works great.
Mac Pro 1.1, SL 10.6.8, 13 gigs ram, DP7, 2 MTP-AV-USB, MTP-AV serial, Microlite, 828mk2, 828mk3, HDX-SDI, 7 other Macs
Re: User survey
DP6.02
OS10.4.11
OS10.4.11
http://www.cueaudio.org
Macpro 3.1 Octocore-16Gb RAM-OSX10.8 - DP 7.24
Macbook pro Core2Duo-4Gb RAM-OSX10.6 - DP 7.24
- philbrown
Re: User survey
5.13 - 10.4.11
- twistedtom
Re: User survey
DP7.01 with Snow Leopard 10.6
Re: User survey
DP 7.01 with 10.5.8 on G5 Dual 2.0 GHz - stable, works great except a few glitches in mixer GUI
Still have installed: 5.13 (used extensively in the past) & 6.02 (used only a few weeks), but haven't needed either of those since installing DP 7.
Bob
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
Re: User survey
At this time see the results below. Some people have multiple systems, for purposes of progress, I took the desktop as the primary system as it generally constitutes the more expensive system and most likely, the studio. This shows what the majority are using, however the survey did not ask what each individual is using their system for, in order for us to really make comparisons. Some people mentioned the stability of their system, which is good, but if we don't know what it's used for, "stable", "rock solid", "working great" etc is relative. May I suggest mentioning commercial and non commercial use as a description? All the same, thanks for chiming in guys
11 of 28 = 38%
DP 7.01 OS 10.6.2
DP7.01 with 10.6.1
DP 7.01 OS 10.6.1
MacPro 8Core 2.8GHZ 16GB RAM OSX10.6.1 DP 7.01
3 of 29 = 10%
DP 7.01 OS 10.5.8
2 of 29 = 7%
1 of 28 = 4%
DP 6.02 on SL.
3 of 29 = 10%
DP 6.02 OS 10.6.1
DP 6.02 SL 10.6.1
DP 6.02 with OSX 10.6.1
2 of 29 = 7%
DP 6.02 Leo 10.5.7
2 0f 29 = 7%
DP6.02 OS 10.4.11
DP6.02 (not broken, as suggested in first post -working great) 10.4.11
5 of 28 = 17%
5.13 with Tiger
DP 5.13 with 10.4.11
DP 5.13, G5 quad 2.5, OS 10.4.11
DP 5.1.3 on OS 10.4.11
5.13 - 10.4.11
11 of 28 = 38%
DP 7.01 OS 10.6.2
DP7.01 with 10.6.1
DP 7.01 OS 10.6.1
3 of 29 = 10%
DP 7.01 OS 10.5.8
2 of 29 = 7%
1 of 28 = 4%
DP 6.02 on SL.
3 of 29 = 10%
DP 6.02 OS 10.6.1
DP 6.02 SL 10.6.1
2 of 29 = 7%
DP 6.02 Leo 10.5.7
2 0f 29 = 7%
DP6.02 OS 10.4.11
5 of 28 = 17%
5.13 with Tiger
5.13 - 10.4.11
1 - "If it ain't broke, don't fix it, but if something BETTER comes along, then make the change".
2 - "If it was easy, then everybody would do it, if you want to be good at it, then slave for it"
3 - "Passion always finds a way"
Re: User survey
7.01 snow leopard
Macbook 2GHz Core 2 duo 2G memory Ultralite DP 7.24 OS 10.6.8
Re: User survey
Also see this post http://www.motunation.com/forum/viewtop ... =1&t=38836
- sdfalk
Re: User survey
10.6.1
DP 7.01
DP 7.01
A Metric Halo ULN8-3D…mmmmmmm
