Greetings,
I'm attempting to connect an 896MK3 and a Phonic Helix board to a Macbook Pro, via the computer's single firewire port. Has anyone been successful in doing this? Both interfaces work seperately, but when I daisy chain them together neither appears in the AudioMidi setup.
Thanks.
Two firewire interfaces?
Re: Two firewire interfaces?
You may need to use a Firewire hub.
I just did, it solved the problem. I wonder what the second port is for if it's not going to work...
Damien Masterson http://www.damienmasterson.com
or enter my name in any search engine
http://www.myspace.com/damienmastersonmusic
http://cdbaby.com/all/damienzm
415 305 7138 dzm@damienmasterson.com
Damien Endorses Hohner Harmonicas and Audix Microphones
It works, just not in the way that you want it to. You can daisy chain a fw hard drive, and you can daisy chain two 896's together. I have a G5, so I daisy chained a 2nd DVD burner off my 896, so I could have two.
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
