RAM: 4 gig• Memory DDR2 SDRAM PC-4200U-444 • for PPC iMac?
Frodo sent me on this quest. I have an iMac with one slot for Ram. I have the 2 gig version of this Memory DDR2 SDRAM PC-4200U-444 • . Does anyone know of a 4GIG version of Memory DDR2 SDRAM PC-4200U-444 that fits into one slot? Need more Ram for the Precious.
http:www.davidosuna.com
Re: RAM: 4 gig• DDR2 PC2-5300 • for PPC iMac?
David:
I'm trying to figure out your exact computer model. You sig says "2.1Mhz"!
I know, it's Ghz-- but the only 2.1 G5 iMac I've found seems to take PC4200 and not PC2-5300, unless I'm mistaken.
In any case, here's the chip:
http://eshop.macsales.com/item/Other%20 ... 0DDR2S4GB/
I just found something that says "for Late 2007 2.0GHz, 2.4GHz, and 2.8GHz models only"...
http://eshop.macsales.com/shop/apple/me ... Core_2_Duo
I received a great deal on this and a week later they released the Intel machines. Ghz? Mhz? Darn wheres my Selectric?Frodo wrote:David:
I'm trying to figure out your exact computer model. You sig says "2.1Mhz"!![]()
I took the numbers from Crucial. Guess I should of looked on my own machine. Here are the specs.
Thanks.
Machine Name: iMac G5
Machine Model: PowerMac12,1
CPU Type: PowerPC G5 (3.1)
Number Of CPUs: 1
CPU Speed: 2.1 GHz
L2 Cache (per CPU): 512 KB
Memory: 2.5 GB
Bus Speed: 700 MHz
Boot ROM Version: 5.2.6f1
Re: RAM: 4 gig• Memory DDR2 SDRAM PC-4200U-444 • for PPC iMac?
This may be a tough one. That 2.5GB may be the real max. I've checked the usual sources and have yet to find 1x4GB PC-4200 for iMac G5.
At some point in this quest I must realize the fact that I am a disenfranchised child of Apple again. Thanks for your help.Frodo wrote:This may be a tough one. That 2.5GB may be the real max. I've checked the usual sources and have yet to find 1x4GB PC-4200 for iMac G5.
