Hi everyone,
Does anybody know if DP 7 will address this? I have to launch a second instance of Kontakt 3 or 4 in DP once I exceed 16 MIDI channels but Kontakt offers 4 banks of 16 in one instance. Never could figured this out in DP 6, I assume it doesn't work?
thanks in advance
Neil
Accessing Kontakt 3 & 4 MIDI port 17-32, 33-48 in DP 7
- tonwurm
Re: Accessing Kontakt 3 & 4 MIDI port 17-32, 33-48 in DP 7
so far I know accessing the other ports is only possible in standalone version of kontakt
at least I´ve never found a way to do that (same in logic, protools...)
DP 7.2, Logic 9, PT HD 8 , G5, macmini with VE Pro
http://www.live365.com/stations/perfect" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; ... /?site=pro
AFAIK, this is a limitation of the AU spec only being able to address 1 port (16 channels) for any AU plug instance.
John Rodriguez - Composer for Media
Mac Pro 2.8, 14 GB RAM, 10.6.1, i7 920, 12 GB RAM, Windows 7
DP7.02, VE PRO Public Beta, Bidule 0.9695, Altiverb 6, Ozone 3
Vienna Instruments, Kontakt 3.5, PLAY 1.2.5, Spectrasonics Bundle
probably the case, Mach V 2 and Ethno do show multiple MIDI banks but that's probably because they are running under MAS.
