AmpGUI DP Themes (now at AMPGUIMODS.NET)
amplidood
Re: AmpGUI7 (always updating first post)
Post by amplidood »
Shooshie wrote:Amplidude, just a question: do your channel meters stay green constantly, or do they go into the red when they reach the last few dB?
By the way, I'm really liking that Gold version. I may adopt that. I'm REALLY starting to wish that we had a menu for skins. It would be nice to use Gold for a while, then switch to iPerformer's night blue, then your gray, etc.
Thanks Shoosh. Your opinion means alot.
You could very easily do the trick of just duplicating the app and applying different mods to each one. I do this as I'm developing them, and have since the beginning. There have been no ill effects.
amplidood
Post by amplidood »
Okay, I think I've nailed just about everything that needs to be at this point. These new versions should last a while, indeed. Yeah right...
I should ask again, was anyone using the Light version?
amplidood
Post by amplidood »
A little teaser on the Gold variation....
Trying to go for less black outlining to make data pop out more.
twistedtom
Post by twistedtom »
I like the gold a lot, not only does it look nice it is easy to see what you are doing. Good job!
Bill OC
Post by Bill OC »
Thanks, 'dood! Taking the time from your real life/work to keep this going is much appreciated here.
Regards,
Bill
Dwetmaster
Post by Dwetmaster »
amplidood wrote:A little teaser on the Gold variation....
Please A'dood can you do a silver version of these inserts for the dark version as well???
amplidood
Post by amplidood »
New gold variation posted. Will check for 7.01 compatibility tommorow.
I gotta say again, I makes me a little sad to realize all the time I may have lost by not using Gimp from the beginning. What a powerful app. Once you get over the non-standard Macness, it's great. I feel like I can work 10x faster and not get so frustrated.
amplidood
Post by amplidood »
Missed a couple elements on the gold variation...reposted.
7.01 seems just fine so far.
amplidood
Post by amplidood »
Ugh the variation sucks. Think I'm going to can that one. Like I've said before, I'm learning about this as I'm going along. Sometimes ya nail it. Sometimes you miss and hit the photographer...he shouldn'a been standing there anyway.
Don't know if this is in the "thinks you can't do" category... but... I just tried the Gold theme, and wondering if the black space in the track overview where the MIDI and audio appears couldn't also be shaded like it is in the Sequence Editor.
BTW, nice looking mod. I tried it and may stick with the stock one, or switch back and forth depending on my mood, but nice work... thanks!
amplidood
Post by amplidood »
James Steele wrote:Don't know if this is in the "thinks you can't do" category... but... I just tried the Gold theme, and wondering if the black space in the track overview where the MIDI and audio appears couldn't also be shaded like it is in the Sequence Editor.
Could you screenshot that? I'm not exactly sure what area you are referring to.
Wait, do you mean can the bottom track list and overview have a drop shadow?
Sorry, I just mean the background that surrounds the soundbites and MIDI data in the right side of the Track Overview window... the "empty measures." It seems the background is gold-tinged in the Sequence Editor but still light grey in the Track Overview.
amplidood
Post by amplidood »
Wow, you're right, the SE does seem a bit off white. I have no idea if I did that or not, never had the intention. I've looked and looked for where to alter the background of the TO with no luck. It's probably hidden in the glogs somewhere.
amplidood
Post by amplidood »
Gold Complete 1.0....just the start. A lot of refining to do.
waxman
Post by waxman »
Is your dark mod finished? the Gold is looking great.
I don't see the pics for the dark mod anymore.
Are you not recommending that one...
waxman
