Thanks,
I have DP7, and the strange thing is that sometimes it works perfectly (every plug in is there) and sometimes not.
I'll try to repair permission after changing the main language and I will let You know (for other Italian users )
Bye
marco
So far the problem has not been solved...
-No Mw eq
-No par Eq
-No Pro Verb
better to stay with the English system even if sometimes the problem appears also with the system in English.
Let's hope for the next DP upgrade...
bye and thanks for the suggestion
marco
Late to the discussion I know.
Got my copy of DP7 day before yesterday and did the following.
1) Un-installed DP-5.13.
2) Repaired permissions
3) Installed DP7
4) Repaired permissions
5) Created a test project imported some audio
6) Add plugins from the list - NO Proverb.
7) Opened the SystemsOptions panel Changed the list sortorder in the "Language and Text" tool.
9) Now ProVerb shows up in the PlugIns list.
I'm not actually sure - the "Repair permissions" was neccessary.
Just did it as a matter of course.
Cheers: Dixiechicken
My God it's full of stars....
Mac Pro 6-Core Intel Nehalem/Xeon 2.93 GHz 32-GB ram, OS-X 10.13.5-Swe, DP-9.52, Unisyn-2.11, 828-MkII,MTP-AV usb, Latest drvs, Wavearts plugs, Kurzweil-2000, Proteus-2000, EPS-16, Pod-II,
Digitech RP-155, Soundcraft UI-16, Emes Kobalt monitors.
