This can be just a little mac application, with its own buffer setting, needed only to run one AudioUnit plug-in. Any suggestions?
Regards,
DLevy
mgr, Legacy Lab
Need to find an AU host to run alongside DP
Re: Need to find an AU host to run alongside DP
Bidule should fill the bill: http://www.plogue.com/?page_id=56.
Independent buffer sizes? I really think so, but I don't have my copy installed now, so I couldn't swear to it.
Thanks Bill. Can anyone else confirm the adjustable buffer in Bidule?Bill OC wrote:Bidule should fill the bill: http://www.plogue.com/?page_id=56.
Yes, but they recommend it be set the same as the DAW. I don't know for what reason though... probably for sync when running audio files in Bidule.
http://www.plogue.com/bidule/help/index.html
Prefs/Disk i/o
Prefs/Disk i/o
Apple has and audio unit host that is included in the Developer Tools Applications/Audio section of Xcode called AU Lab. A copy of the Xcode is included on your OSX install disk or the most current version is available for download here http://developer.apple.com/technology/xcode.html. The latest release is Intel only and unfortunately they don't make previous versions of Xcode available for download for the PPC folks. Regardless, you should have AU Lab version 2.01 (UB) or better (2.10 Intel only). Earlier versions are a little quirky and don't support VIs. If you download the latest Intel Xcode package or install it from your OSX disk, you can use Pacifist (http://www.charlessoft.com/) to install just AU Lab and it's documentation with out installing all the other stuff. It's actually a pretty deep little program if you take the time to learn it.
DP8.06 PT11.2.0 VEP 5.3.x
RAX
el Ocho 2.8 running DP6 & RMX with M5II - 828mkII / el Quatro 2.66 running Vienna VI & Vienna Ensemble, RAX 2, M5II & L8 for VSL - 2408mkII / steiner MIDI EVI, Oberheim Xpander, M5II reading UVI .dats, Radium 61 controller
http://www.ronmeza.com
Paris mini studio : iMac 20" intel 2.66 core duo (spring 2009) DP 6.02 - Firebox running M5II & Independence Pro 2.1 connected to Mac Mini (spring 2009) - Firebox running L8, RAX 2, Independence 2.1, M M5II
Keystation 49e controller
