DP7 is constantly crashing when I enable/disable aux tracks, or change the outputs of MIDI tracks.
So basically, here is what I did:
1. Created a new empty DP7 project
2. Imported my VI v-rack and main sequence chunks from a previous template, including bundles. This includes several aux tracks in the main Tracks Overview window, with MIDI, Audio, and Aux tracks organized in folders.
3. Renamed the VI's in the v-rack as needed
4. Renamed and re-assigned bundles as needed.
5. Re-assigned any tracks in the T.O. window as needed.
Through this process, DP crashes after adjusting a few MIDI track outputs, enabling/disabling Aux tracks, or assigning Bundles in the Bundles window. The only VI I have instantiated is several instances of the Vienna Ensemble Pro plugin. I also have Bidule rewired to DP, and have aux tracks set up in the T.O. to handle the Bidule Rewire audio inputs.
I spent the last year working in Logic because of the instability of DP6. I jumped on DP7 based on some of the glowing initial reports, hopeful that it would be stable. Fingers crossed that someone can see a problem with what I am doing and offer a possible solution. I really don't want to go back to Logic! DP is so much deeper for scoring and composing in general.
Ideas, anyone?
As a side note, I noticed that MOTU seems to have sorted out the numbering issues that I used to see in the Bundles window in 6.02. This is very cool. I am wondering if renaming the bundles is causing some of these problems?
