Switch from 24bit to 32bit in a project?
Chao
Post by Chao »
I have an early project originally done in 24bit. Though there may not be advantage, I tried to switch to 32 bit, it didn't work. 32bit selection is grey and can't be selected. Why is that? Actually I tested a new simple project started as 24 bit, but I can still change it to 32 bit later. Does this have anything to do with virtual instruments or..... any idea?
Newest Studio Recording, my solo cello composition: http://www.cjchang.org/website/music_4moods.htm" onclick="window.open(this.href);return false;
Composer Chao-Jan Chang's website: http://www.cjchang.org" onclick="window.open(this.href);return false;
mhschmieder
Re: Switch from 24bit to 32bit in a project?
Post by mhschmieder »
Remember that the 32-bit option in DP is for floating-point not fixed-point (some apps indeed do support 32-bit fixed point files).
There was an earlier discussion about the utility of floating-point vs. fixed-point file storage.
I personally only use 32-bit floating-point files for audio restoration work, so that each phase of the restoration work is saved "without conversion" to/from the internal format that is used within the restoration workflow, until the final stage where I save to 24-bit fixed-point Broadcast Wave.
Chao
Post by Chao »
mhschmieder wrote: There was an earlier discussion about the utility of floating-point vs. fixed-point file storage.
Thanks! I did read that thread but it's not related to switching between them in a project.
