Ext HD Multi-drive solution?
jisley
Post by jisley »
I have several SATA hard drives lying around that I would like to put to use. I'm looking for a multi bay, hot-swappable, preferably firewire 800 bay that I can put these drives in for backups, sample storage, archiving, etc.
I've seen a few things but many are hardware RAID and I'd like the option of NOT using RAID if I can.
Any suggestions?
Thanks,
John
__
Mac G5 Quad 2.5, 2GB RAM, MOTU 828 MKII, OSX 10.5.8, DP 6.02, 3 x UAD-1
__
"Some days you get up and put the horn to your chops and it sounds pretty good and you win, some days you try and nothing works and the horn wins. This goes on and on and then you die and the horn wins."
-Dizzie Gillespie
kgdrum
Re: Ext HD Multi-drive solution?
Post by kgdrum »
not exactly what you are looking for but I use and recommend Firmtek/Seritek
they have bundled HD enclosures with a sata card for the Mac.OWC sells this:
http://eshop.macsales.com/search/firmtek
good luck
KG
ripeart
Post by ripeart »
John
Just out of curiosity why don't you want to use RAID?
'11 MacBook Pro 10.6.8 i7, 8GB, DP 7.22 | Spectrasonics Omnisphere, Absynth, NI Komplete, Waves Mercury, Nugen, SoundToys
Dynaudio 6a, Avantone Mixcubes, Event 20/20, Focusrite ISA One, DBX 160x, DBX 386, DBX 1066, Mindprint, 828.2, Lexicon PCM-91, Oxygen 25, Yamaha P-85, Midisport 2x2
Neumann TLM-103, Rode NT1a, Fathead Ribbon, Fender, Gibson, Taylor acoustics, PRS & Schecter guits, Vox VT120+, GK-MB112, etc...
kgdrum
Post by kgdrum »
most people find the risks associated w/ raid setups, outweigh the potential benefits.
ripeart
Post by ripeart »
kgdrum wrote:most people find the risks associated w/ raid setups, outweigh the potential benefits.
I'm not sure what you mean. The "potential" benefits? If one were to compare a single disk versus a typical fault tolerant RAID array the foregone conclusion is that the RAID array is by far more reliable. This is tried and true, for a long time now.
Granted, in a typical RAID 5 array seek time (depending on the controller) is generally considered to be slower than a single drive or RAID 0. That's really the only downside to employing RAID 5. RAID 10 & 50 mitigates this issue however.
Please explain what risks you are referring to.
martian
Post by martian »
It'd have to be a blacker friday the 13th if 2 drives were to go on the same day..
I may try using the RAID 1 ( mirroring ) in the internal case
or I am I better getting an external box and stuffing it full of 4 Tb drives?
I just want something secure that I can switch on and not worry about until a red light flashes somewhere...
http://www.fork-media.com
ripeart
Post by ripeart »
The internal RAID option is software RAID which eats CPU cycles.
Best bet is to put those drives in a reliable enclosure with a hardware RAID chipset. A slightly less appealing option (due to potential driver issues, heat, and noise) is to install a hardware RAID card in your Mac and connect the drives to that.
Jeez, just realized the OP was from 2009, sorry for the resurrection, lol. :banghead:
However maybe some will come across this post and realize that the Mac OS RAID option is software RAID and definitely not a good solution for DAW scenarios.
