MAD AS HELL WHY "NO AUDIO DEVICE FOUND"
I BOUGHT MOTU ULTRALITE MK3 LAST NIGHT AND VISTA WILL NOT DETECT THE AUDIO DEVICE VIA FIREWIRE. NOW I AM NOT SURE IF THIS IS VISTA OR THE MOTU OR BOTH, I AM USING THE ONBOARD FIREWIRE, SHOULD I BUY PCI FIREWIRE CARD IF SO WHICH ONE? SHOULD I TRY A FIRE TO USB CABLE WILL THAT WORK??? I AM SO FUSTRATED, MOTU WAS RECOMMEND SEVERAL TIMES AS A GOOD INTERFACE BUT I AM WONDERING IF THAT IS ONLY FOR MAC??? I HAVE TRIED EVERYTHING I CAN THINK OF I HAVE THE LATEST DRIVERS FROM MOTU THE SOFTWARE IS ON MY PC BUT CAN'T DETECT THE AUDIO DEVICE. I NEED SOME DIRECTION OR I WILL HAVE TO TAKE THIS BACK. I HAVE ALSO READ A LOT OF POST ABOUT CRACKING AN DELAYS I AM REALLY WONDERING IF I HAVE BOUGHT THE WRONG PRODUCT
Re: MAD AS HELL WHY "NO AUDIO DEVICE FOUND"
First off...the all caps thing...no.BMOG wrote:I BOUGHT MOTU ULTRALITE MK3 LAST NIGHT AND VISTA WILL NOT DETECT THE AUDIO DEVICE VIA FIREWIRE. NOW I AM NOT SURE IF THIS IS VISTA OR THE MOTU OR BOTH, I AM USING THE ONBOARD FIREWIRE, SHOULD I BUY PCI FIREWIRE CARD IF SO WHICH ONE? SHOULD I TRY A FIRE TO USB CABLE WILL THAT WORK??? I AM SO FUSTRATED, MOTU WAS RECOMMEND SEVERAL TIMES AS A GOOD INTERFACE BUT I AM WONDERING IF THAT IS ONLY FOR MAC??? I HAVE TRIED EVERYTHING I CAN THINK OF I HAVE THE LATEST DRIVERS FROM MOTU THE SOFTWARE IS ON MY PC BUT CAN'T DETECT THE AUDIO DEVICE. I NEED SOME DIRECTION OR I WILL HAVE TO TAKE THIS BACK. I HAVE ALSO READ A LOT OF POST ABOUT CRACKING AN DELAYS I AM REALLY WONDERING IF I HAVE BOUGHT THE WRONG PRODUCT
Secondly, the drivers that shipped on CD with my MOTU Ultralite did not work with Vista 64...so if you are using the 64 bit version of Vista make sure you download the latest drivers.
Thirdly...there are times when my (Lucent Chipset) firewire card doesn't recognize the Ultralite in Vista unless I start the Ultralite when the PC is turned off (using the supplied power adapter). Try turning the Ultralite on while the PC is shut off and then boot up.
- Primary DAW OS: Windows
Get a pci firewire card with a Texas Instrument chipset. MOTU recommends the same for their audio interfaces.BMOG wrote:I BOUGHT MOTU ULTRALITE MK3 LAST NIGHT AND VISTA WILL NOT DETECT THE AUDIO DEVICE VIA FIREWIRE. NOW I AM NOT SURE IF THIS IS VISTA OR THE MOTU OR BOTH, I AM USING THE ONBOARD FIREWIRE, SHOULD I BUY PCI FIREWIRE CARD IF SO WHICH ONE? SHOULD I TRY A FIRE TO USB CABLE WILL THAT WORK??? I AM SO FUSTRATED, MOTU WAS RECOMMEND SEVERAL TIMES AS A GOOD INTERFACE BUT I AM WONDERING IF THAT IS ONLY FOR MAC??? I HAVE TRIED EVERYTHING I CAN THINK OF I HAVE THE LATEST DRIVERS FROM MOTU THE SOFTWARE IS ON MY PC BUT CAN'T DETECT THE AUDIO DEVICE. I NEED SOME DIRECTION OR I WILL HAVE TO TAKE THIS BACK. I HAVE ALSO READ A LOT OF POST ABOUT CRACKING AN DELAYS I AM REALLY WONDERING IF I HAVE BOUGHT THE WRONG PRODUCT
This firewire card is OK: http://www.guitarcenter.com/ADS-Tech-PY ... 1391105.gc
If you don't like the audio interface you bought, return it.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
SONAR X1a Producer
