Babz wrote:Cool! I didn't know about Orange Tree basses (demos sound great on website), so thanks for turning me on to that!
In terms of the zip file question... It's hard to answer, not being there and knowing exactly how you're doing the transfer of the entire library. Like, for example, if you have a large Kontakt library, and it's all on an internal drive, the easiest way would probably be to just do a Finder drag copy to an external drive and transfer your whole library like that.
In terms of the zip files ... You don't necessarily need to keep the zip files on your hard drive, once you've installed the library. They are just taking up extra disk space. But you might want to keep them as a backup, since it was a downloaded product. It's a question of how it all fits on DVDs. If you can fit the entire library on a DVD, uncompressed, just do that. It saves the time it takes to uncompress. But if a library turns out to be too big to fit on a single DVD, but it DOES fit on one disk when it is zipped, then you might want to burn the zip to DVD for the convenience of having the entire library on one disc. So, as I see it, it is a matter of how things fit on discs, the convenience of having that vs. the extra time it takes to uncompress. Like I say, it's hard to say since my decision on this would be based on the actual file sizes, etc.
As a general rule, if you've already invested the time uncompressing, and you can fit the uncompressed version on discs in a way that works for you, burn the uncompressed files to disc and trash the zip file. Does any of this make address what you are getting at in your question?
Hope that helps and doesn't confuse.![]()
Babz
the libraries I want to save to on a dvd are the Orange tree Cherry and Pear Bass's so not very large,should I save the file as it came with the download before I unzipped it?
KG
