DP CPU Usage
tencentcat
DP CPU Usage
Post by tencentcat »
I'm new to DP, and I can't seem to find an answer to this searching the forums. Does Digital Performer take advantage of dual processors? I have a dual 1.25ghz G4 with 1.25 gb of ram, and it just seems that DP is extremely power hungry according to the CPU meter.
I've tried different buffer and clock settings settings, but even at 24/48khz the meter will spike just arming a track to record. Just playing back a few tracks taked the meter a third of the way up. I don't see how I can get a full project going this way. Any tips?
Morpheo
Re: DP CPU Usage
Post by Morpheo »
Yes DP is optimized for dual processors.
How many voices/busses do you have in your 'studio settings (menu setup>configure audio system>configure studio settings) ?
Mac Pro 5,1 12-core 2.4 GHz//40GB RAM//RX 560//macOS 10.13.6//SSDs//MOTU 896//Keylab 88//Faderport 8
Pro Tools 2018.7//LPX 10.4.1//DP 9.51
NI Komplete Ultimate 11//Albion One//Soundiron Choirs//Pianoteq//Analog Lab//VSL SE & Chamber Strings//etc
tencentcat
Re: DP CPU Usage
16 mono and 16 stereo voices, which is the default setting. I haven't really changed anything but the clock speed and bit rate.
Splinter
Re: DP CPU Usage
Post by Splinter »
Change the buffer settings in Hardware Setup. Try 512 or 1024 and see if that helps.
MacBook Pro Quad 2.4GHz i7 • 10.12 • 16G RAM • DP 9 • MOTU 896HD Hybrid, Apogee Duet, & MOTU Micro Lite MIDI interface • Waves Platinum, Studio Classics Collection, Abbey Road, etc... • Fabfilter Pro-Q2 • Soundtoys FX • IK Amplitube 3, Ampeg, and TRacks 3 • Altiverb 7 • Slate Digital Everything Bundle • Stylus RMX • Komplete 10 • SampleTank 3 • Arturia V Collection • M-Audio Axiom 49
tencentcat
Re: DP CPU Usage
I tried changing the buffer setting. It makes a noticeable difference on the meter, but I need lower settings for live tracking. I'm on version 4.52 by the way.
midiw
Re: DP CPU Usage
Post by midiw »
Well according to mother MOTU @
http://www.motu.com/techsupport/technotes/document.2004-05-04.0146026746/view?searchterm=dual%20processors
Does Digital Performer 4 support multiple/dual processors?
Yes, the dual processor performance bar is no longer necessary as support is already built-in to the application. Digital Performer 4 has been optimized to utilize multiple processors in OS X. You can find this information on Page 9 and 28 in the Getting Started Guide.
Hope this helps.
Mac OS: Mojave
tencentcat
Re: DP CPU Usage
Thanks for the input. That's encouraging that it's not wasting power. I'm just a bit shocked at how much it seems to use for tasks that don't even register in Logic (not to make an uneducated comparision). I've heard the CPU meter in DP is not exactly accurate - any truth to this? Should I just ignore it and not worry about hitting the ceiling?
Freddy Bloggs
Re: DP CPU Usage
Post by Freddy Bloggs »
MHO
DP4.52 is very cpu hungry, so a slower processor - hard to believe but dual 1.42 is slow compared to G5 2.0 & up - you will have to use higher buffer settings for good performance.
Sucks for tracking, actually unusable imho, but works well for mixing etc.
Even tho the CPU meter is supposedly innacurate, at low buffer settings the system does crap out with minimal voices/VI's.
I have a dual 1.8 G4 gigadesign cpu. 1024 is my basic setting & that works well for mixing. I switch back & forth to lower buffers for tracking soft synths. It works, but it's not the ultimate solution.
From what i read here & on OSX Audio the G5 is much faster for DP than the G4.
Now i'm gonna eat my pizza.
Siryne
Re: DP CPU Usage
Post by Siryne »
tencentcat: you don't say which audio interface you are useing. If it is MOTU then Cuemix is your friend. Gets you latency free monitoring so you can run the higher buffer settings.
Peace!
Mac Pro Quad "Nehalem" Xeon 2.93 Ghz-12GB RAM - OS 10.6.4-DP 7.21- & Logic 9.1.3 - MOTU 896HD- Apogee Big Ben-Tascam US2400-UAD2 Duo-Altiverb 6-Melodyne Editor-Autotune Evo-Plugins from UAD, URS, PSP, Abbey Road, Flux-VI's- LASS-EWQLSO-VSL-Kirk Hunter VS Pro-Kontakt 4 -Manley Voxbox, Brauner VM1, Soundelux E47C & much more.
EDL
Re: DP CPU Usage
Post by EDL »
I have dual G5 (2v1.8 revision 2) and small buffer make the CPU gauge easy to fill out... In fact, no really matter the host : using small buffer is intensive.
Even with the G5, I wouldn't consider buffer less than 256 if I need juice. I mean, using 64 sample buffer, I can maxout with 4 altiverb, while with 1024 samples, it can run over 20 instances (mono to stereo 2,8s lengh) !
aerodynamics
Re: DP CPU Usage
Post by aerodynamics »
Could heat be the culprit?
I'm seeing very similar behavior from my setup (CPU spikes just from record arming, pops and clicks during tracking/playback). Some days its good to me, others its not. What I've noticed is that when this happens and I call it a night, the next day it works w/o a hitch. When it acts up, I shut everything down - all hardware, hard drives, etc. I give it an hour or so and try again. I get about an hour of trouble-free work before it gets the hiccups again. This leads me to believe that heat, either on the processor or hard drive side, is causing this.
I normally record at 88.1, 24-bit. I've tried every buffer setting, cut down on voices, everything. I'm running outboard effects so it's not a plug-in issue. Assuming I'm right about my heat theory, what can be done to remedy this? I could blow a big ol' fan towards the laptop vents! While that would be okay when I'm tracking synths and drum machines, it would be a no-no recording anything live. Or am I SOL and need to pony up for a G5? If you're wondering what's in my setup, see my sig.
Apple Powerbook AL, 1.25ghz, 1gb ram, 160gb ext. hd, OS 10.2.8/MOTU 828MKII/DP4.1/MPC2000XL modded w/ int. multi card reader, max. ram, 8-out card/Korg Triton Pro/MiniMoog Voyager analog synth/Lexicon MPX1 effects/Langevin DVC pre-eq-limiter/Technics 1200MKII/Audio Technica 4033CL mic/tons of vinyl, cds, dvds, vhs...ready, willing, and able to sample anything!
motuguy
Re: DP CPU Usage
Post by motuguy »
Originally posted by Fred Bloggs:
MHO
How did you ascertain that?
I usually have DP's CPU panel open/running and really have not seen it max out unless I use far too many AU/VST virtual instruments.
I've also ran the Activity Monitor and Cunning Fox and not really seen DP hog my cpu.
So I am really interested how you ascertained that DP is a CPU HOG.
QUICKSILVER G4 dual 1G process with 1.5 GB RAM
audiophile 2496 PCI card(MIDI/audio in/out)
running TIGER and PANTEHR
M-Audio USB MIDIsport 8 x 8 (MIDI interface)
8500/Sonnet G3 + USB and Firewire cards running PANTHER and OS 9
9500/Sonnet G4 + USB and Firewire cards running PANTHER and OS 9
dmshep
Re: DP CPU Usage
Post by dmshep »
I've found it fairly easy to max out our dual 1.25 with 2GB of RAM. 7 or 8 instances of UAD plugs, Waves on most channels, and some automated plugs and it starts getting woozy. I think I should be getting more power out of it than I am, but can't seem to figure out why it bogs down so quickly. I'm running it at 1024.
Off-topic, I suppose, but I've been trying to figure out a problem with the UAD card where the DP CPU meter will suddenly spike and stay full and red until I remove one or two UAD plugs, and then it's happy again.
Tomas E
Re: DP CPU Usage
Post by Tomas E »
I had a similiar problem some years ago. Below is a quote from MOTU Tech Support:
"Try setting the Disk Cache in the memory control panel to the lowest
setting (96 or 128K). This usually clears up problems with disk spiking."
DP may however alert you about the low Disk Cache setting.
inukshuk
Re: DP CPU Usage
Post by inukshuk »
e-snobben
I checked and there is no Disk Cache settings in DP or Panther OS X. I did a find and no results came up.
Dual G4, 1.42GHZ, 2,048 ram, 3-74gb Raptors, 1-250gb Caviar, OS X Tiger 10.4.5, D.P. 4.61, HUI, Tannoy 600a's, UAD-1,Fairchild, Pultec-Pro, tc PowerCore firewire, Restoration Suite, MD3, VSS3, Inflator, Voice Modeler, Assimilator, Auto-Tune4, PowerCouple, PSP MasterQ, Vintage Warmer, MixPack, Blue Tubes Bundle, BFD, motu 896 HD.
http://www.inukshukproductions.ca/mastering
