Can't get Reason to open inside DP5.13
yofo
Post by yofo »
I upgraded to DP5 several months ago and have never gotten Reason 2.5 to open.DP crashes everytime I try to open Reason inside, Reason will open by itself but not inside DP5.13. I don't use it much but am finally getting around to asking the experts(you guys). Thanks in advance.
Mac OSX 10.6.8 2 x 2.66 GHz dual-core Intel Xeon 8GB 667 MHz DDR2 FB-DIMM RME Fireface 800
Mr_Clifford
Re: Can't get Reason to open inside DP5.13
Post by Mr_Clifford »
You might need to re-install Reason or something. I used to run Reason 2.5 with DP5.13 on a system similar to yours with no problems. Running it now with DP6.02 also with no problems (DP6.01 had major problems with Reason, but not crash related). Sounds like something weird has happened with Re-wire on your computer.
willheim
Post by willheim »
I run Reason 3 - it is a little weird sometimes but works - you gotta launch DP first, rght? or is is the other way round? Too early no coffee. but make sure you are doing that right, and that you have some inputs in a DP audio track set to the reason buss.
I just discovered that DP can pick (mid like) inputs on reason just thru the bussing available in the the instrument selection area instead of MIDI.
mac pro 2.66 2010 8 core w 48 gig 1600 ddr, Mac OS 10.6.8, DP 7.21, the usual plugs and stuff.
dosuna11
Post by dosuna11 »
There is a rewire fix at propellerheads site http://www.propellerheads.se/download/u ... isplaymain
iMac 2.7Ghz quadcore i5 16 gig RAM DP 7.24 OS 10.6.8, iMac G5 2.1GHz 2.5 gig Ram DP 5.13 OS 10.4.11 MOTU 828 MK2, East West Platinum Plus, Miroslav Philharmonic, Komplete 5, Kontakt 2 Garritan Big Band, Mr Sax T, The Trumpet, DrumCore, Trilogy and Trillian, Ivory, MachFive, Ethno Instrument, Reason 4, SampleTank 2 Sampletron, Samplemoog, Melodyne Editor, Nomad plugins, Vintage Warmer, Ozone 4, Amplitube Jimi, Xgear and AmpegSVX.
http:www.davidosuna.com
kassonica
Post by kassonica »
yofo wrote:I upgraded to DP5 several months ago and have never gotten Reason 2.5 to open.DP crashes everytime I try to open Reason inside, Reason will open by itself but not inside DP5.13. I don't use it much but am finally getting around to asking the experts(you guys). Thanks in advance.
Reason 2.5 is not supported by either intel or leopard to my knowledge.
