How many ppl that are have the BTD issue are using Altiverb??
i dont remember ever having this problem before i bought this plug???
maybe update??
does altiverb have to do with btd problem??
- HLStudios
PowerMac PPC G5 Dual Processor 2.0Ghz 4GB RAM 720GB HD OSX 10.5.7 (Leopard)
MOTU 424 PCI-X Card / MOTU 2408 MKIII / Focusrite Octopre / M-Audio Axiom 61 / TC Electronic Finalizer / M-Box
Digital Performer 6.02 / Pro Tools 8 / Peak Pro 5 / Reason 4 / BFD 1.5 / Addictive Drums / Antares Auto-tune /
Nomad Factory Analog Sign. Pack / PSP Audioware / Voxengo / Sonalksis / Celemony Melodyne / T-Racks 3
a pair of acoustic guitars and basses..lots of creativity!!
Re: does altiverb have to do with btd problem??
Hard to believe Altiverb could be trouble, what with the amazing DP support Audio Ease provides.I suppose anything is possible.
I see from your sig that you have a MOTU audio interface. If so, then are you aware that you
can do real-time mixdowns by going to CueMix control panel and checking "Mix 1 mirrors
computer output"? Then add "Mix 1-2" as a bus in your project, create a Stereo track, and
set its input to "Mix 1-2". Then just record your mix in real-time to that stereo track.
(Don't play back the resulting track along with your other tracks, of course).
The newly recorded stereo mix can be exported as a soundbite to a folder on your
desktop or any drive and imported into the audio editing program of your choie,
such as Peak.
I haven't used Bounce-To-Disk in three years. Real-time mix recording sounds better, too.
And not just incrementally - it's a big difference.
Furthermore, you don't even have to create audio tracks of the output of VI's if you
use the real-time pass method of recording your mix.
such as Peak.
http://www.davepolich.com
Gee Dave, I do Real-Time Mixing as you describe, too. Works great, and also allows one to combine external MIDI instruments in the mix.
