Hi guys
I have a project set up with 20 or so different sequences using a number of different V-Racks. After doing most of my work on these sequences, I've realized I need to add a few identically configured tracks to each - same name, ins, out, etc. Is there a way to set up these few tracks on one sequence and then copy them to the other sequences? Or will I need to do the setup work manually for each sequence?
I've looked at clippings, but that seems to just be data. Load only seems to work for chunks, etc. Any think I'm missing? I'm hoping there's an obvious solution. Thanks for your help.
Derek
Copy tracks from one sequence (chunk) to another
Re: Copy tracks from one sequence (chunk) to another
If the clipping is dragged into the left side of the Tracks or Sequence window (where the tracks names are) new tracks will be created.
You can also Load in a sequence, make a selection in the data field of the desired tracks, then drag the selection (from the data field) into the track names area.
Dragging a chunk icon into the track names area will add all of its tracks.
Thanks, Tim. The first option worked great. It's what I was trying to do before, but just wasn't dropping the clipping in the right place.
Thanks again.
Derek
Thanks again.
Derek
