Hello,
Is Mach Five working stable in 64 bit?
Would be running in x64 Vista/Win 7,is anyone running this setup successful?
Thanks for any help you can offer....
Is Mach Five 2 working stable in 64 bit?
Re: Is Mach Five 2 working stable in 64 bit?
Anyone using it in either Vista64 or Win7 64,care to say how the performance is on 64 bit? Thanks in advance..
hey bobbybland,
I've try MachFive v2 with Vista Ultimate 64 > Stand-alone mode works fine but still with the usual quirks that can 'cause one to loose confidence in the tool.(ie, crashing when you've got inspiration and momentum going).
Running it in Reaper v2 64-bit version doesn't work. It cannot be detected so am not sure what the 64-bit hype is all about. 32-bit plugin works fine in Reaper v2 but I have not got a chance to test it with the latest v3 yet. Hope that helps out a bit.
AMD 9850 QuadCore - Vista 64 Ultimate/WINXP SP3 Dual-Boot, 8gb RAM - 2xNvidia 1GB 8800GT SLI - Reaper 3.x-current,Propellerhead Record+Reason 4, Battery 3, BPM v1.0.x-current, MachFive 2, NI Intakt v1.03,other assorted plugz.
Edirol M-16DX Digital Mixer, JoeMeek TwinQ Pre, Audio Technica AT4047, Sure SM57, M-Audio LightBridge ProFire & Delta 1010 PCI, ClearSonic Isopac-E Vocal Booth, a whole sea of love for recording and music making process.
Thanks Red. .I ended up buying it,and haven't tested it in x64 yet so far in 32 bit on Vista64 it seems to work fine..
Thanks again..
Thanks again..
