I am using Dp 6 with Metric Halo ULN2 now. I want to change the "Input Monitoring Mode" setting (Setup> Configure Audio System> Input Monitoring Mode>.....)to "Direct hardware playthrough", but it is on " Monitor record-enabled track through effects" mode which can't be changed.
Looks like the Direct hardware playthrough only works with MOTU's own audio interfaces. Is there anyway to get the job done?
Any idea? Thanks!
Can't change Input Monitoring Mode setting?
Newest Studio Recording, my solo cello composition: http://www.cjchang.org/website/music_4moods.htm" onclick="window.open(this.href);return false;
Composer Chao-Jan Chang's website: http://www.cjchang.org" onclick="window.open(this.href);return false;
- Tritonemusic
Re: Can't change Input Monitoring Mode setting?
That is correct.Chao wrote:Looks like the Direct hardware playthrough only works with MOTU's own audio interfaces.
Not quite, it works with my M-Audio FW 1814
MacPro 2x2.66 GHz Dual-Core Intel Xeon, 7 Gb RAM, DP 8. 04, MOTU Track 16,MOTU 8pre, Ethno Instruments 2. BPM 1.5, Electric Keys, Waves Diamond, Basses and Guitars
- Mr_Clifford
Generally for non-MOTU audio interfaces, you turn the input monitoring to 'off', then use the software control panel that comes with your audio interface to route a latency-free signal of your input to your speakers. Depending on the interface it might be basic or it could be a complete virtual mixer like with the RME cards.Chao wrote: Looks like the Direct hardware playthrough only works with MOTU's own audio interfaces. Is there anyway to get the job done?
