Safari 4 is out.
stephen1212b
Re: Safari 4 is out.
Post by stephen1212b »
gavspen why do you think it requires 10.5.7 ? I am still on 10.4.11 and it seems to be running fine.
Mac OS X version 10.5.8 / DP 7.12 / Dual 1.25 GHz G4 2GB DDR SDRAM / MOTU 2408mk3 / Powerbook G4 / traveler
Matcher
Post by Matcher »
Just installed S4 to my Vista Ultimate 64bit desktop. Probably the fastest browser there is, though Google's Chrome is nice too.
MBP i7, OSX 10.7.4
gavspen
Post by gavspen »
stephen1212b wrote:gavspen why do you think it requires 10.5.7 ? I am still on 10.4.11 and it seems to be running fine.
The download of Sarafi 4 for Tiger is a different one than the one for Leopard. If you're running Leopard, the Sarafi 4 installer tells you that you need 10.5.7. At least, it does at my house :wink:
From the website....
Macintosh Requirements
Any Mac running Mac OS X Leopard 10.5.7 or Mac OS X Tiger 10.4.11 and Security Update 2009-002
Gavin
Mac mini M1, 14.7, 16gigs RAM, 828 mk3 Hybrid, DP 11.31, Various VIs
jlaudon
Post by jlaudon »
10.5.7... well it's a choice between Safari 4 (update to 10.5.7) or DP6 (stay on 10.5.6). No choice really :wink: Oh well, Safari 4 runs nice and quick on my Powerbook G4.
MacBook Pro 2021 (M1 Ultra) with 64 gigs RAM. DP 11.23
stephen1212b
I can't believe that two different versions of Safari 4.0 (4530.17) one for Tiger and one for Leopard would both share the exact same name and version number. What is your build version # ? On the other hand Leopard may not be compatible until version 10.5.7 just as Tiger isn't compatible except for version 10.4.11, or more likely only these versions are tested and supported. The installer program checks all this out, but you can always drag an install into another environment and see what happens.
Snnnappy!
HCMarkus wrote:Snnnappy!
...or "snap snap?"
kgdrum
Post by kgdrum »
i generally use firefox,seeing this thread I decided to try safari 4,
Wow!! it is quick ,very nice update,works well on my system.
thanks for the tip.
it seems this new update is not well publicized
