recording dj mix through ultralite mk3
jpetrou
Post by jpetrou »
hey guys, i need help recording my dj mix into cubase5 using my ultralite mk3. I have the RCA going out from my mixer to the channel 3in 6.5 plug into the ultralite.
i get a recording, although it is very very quiet. how do i turn up the track? is it done on the ultralite or in cubase5?
probably a simple question but i have looked everywhere and cant find it, and im new to production.
thanks.
INTEL i7 920
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
HotShot
Re: recording dj mix through ultralite mk3
Post by HotShot »
Hi:
Increase the input gain on the Input tab of CueMix FX. I hope you have the lastest drivers (3.6.8.1410).
If you don't get a strong enough signal by increasing the trim to max for the input of the UltraLite ( I think you said ur using input 3-4), you may have to use a preamp.
That means you would send your mix to a preamp before you send it into the UltraLite. The preamp can be used to increase the signal gain to a good enough level.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
jpetrou
Post by jpetrou »
i turned up the input on the cuemix and in cubase the mixer channel to max and it records at a good level now. thanks for the help.
can i ask you bout your pc. iam gonna install vista64 ultimate. have you had any dramas with it?
INTEL i7 920
GIGABYTE EX58-DS4
6GB DDR3 (1600mhz)
4xSEAGATE 500gb HDD
XP32 sp3
CUBASE 5
REASON 4
HotShot
Post by HotShot »
I've had great results with Vista 64.
Go for it.
SONAR X1a Producer
