New MOTU Firewire/USB 2 Drivers Have been Posted. 3.6.8.1410
peddap
Re: New MOTU Firewire/USB 2 Drivers Have been Posted. 3.6.8.1410
Post by peddap »
Could anyone please find out if the labeling issue of the mixes and inputs are fixed? I.e. if they are allowed to be edited...
I can't find out for my self for more than a week due to a vacation :?
HotShot
Post by HotShot »
I never knew Inputs could be renamed.
Mixes can be named and renamed by using "Create New" Or "Save To" options under the Configurations Menu. The new name is placed under the Configuration menu.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
robleighton22
Post by robleighton22 »
HotShot wrote:Hi tricky:
The word out is that if you don't have a mk3 model, you might want to stick with an older driver such as 3.6.7.4. because the newer drivers have introduced higher latency to accomadate for the onboard DSP effects of the mk3 units. The newest driver does add new audio analysis tools (posted in my 1st post of this thread), but some non-mk3 users rather stick with the older driver (2.6.7.4) because the lowest hardware buffer size is 32, in contrast, the newest driver has 64 as the lowest hardware buffer size.
It's always best to uninstall the older driver before installing a new driver.
i cant get the 3.6.7.4 drivers to work on windows 7 - anyone been successful (32-bit version), tried windows vista sp1 compatability mode - the drivers install, cue mix works, but the sound card does not actually show up as being plugged in.
tricky
Post by tricky »
HotShot wrote:I have the UltraLite-mk3. I'm not sure if the 3.6.7.4 is the best driver for the Traveler, but I have read good reports about that driver version.
You can install the new driver (3.6.8.1410) for the Traveler. It's just some are concerned about keeping the driver version that has the 32 hardware buffer size option, and the 3.6.7.4 has that size.
At a 44.1 sample rate, 11ms latency would mean that the hardware buffer is set at 512 samples and the latency will be a smaller size at higher sample rates.
So with the new driver's lowest hardware buffer setting of 64 samples. you will have a 1.5ms latency reading at a 44.1 sample rate. With a hardware buffer setting of 64 used, SONAR reports that the ASIO reported total round trip latency is 6.1ms. In my opinion, that's not bad, but not as low as the total round trip latency that is possible with non-mk3 units and the 32 hardware buffer size selected.
Hope this helps.
Many thanks Hotshot will try the older drivers
tricky
Post by tricky »
Hi guys trying to update the drivers on my traveler has caused some problems i have firmware version 1.07 i uninstalled the older drivers 3.6.7.3 and installed 3.6.7.4 everything seemed to go ok and was given the message that the drivers were successfully installed, the problem now when opening cubase, acid pro 6 etc i get the message no MOTU detected please make sure the taveler is plugged in and the drivers are installed. device manager indicates that the device is ok, been at this for hours and hours now any ideas. thanks
timmytubby
Post by timmytubby »
So when I saw the new drivers I downloaded and installed them instantly.
But now when I open CueMix FX the software opens for all of about 5 seconds and then blue screens my computer!!
So I re-installed and some thing happens.
So I manually went through my computer and deleted every reference to MOTU and did the same in the regedit. My computer was then devoid of anything of MOTU, and I re-installed the new drivers.
Guess what. Same problem!! Only now I can't roll back the drivers to the previous ones!! And the old ones I can't seem to find on MOTU's website either.
Can anyone help?
Mark S
Post by Mark S »
which version? Did you see the driver sticky at the top of this forum?
timmytubby
ERrm, When you say which version, It'll be the version that is currently up on the MOTU website, the one with all the new tools that nobody seems to want.
I haven't seen the driver sticky. What is it?
tricky
Post by tricky »
Hi timmytubby try this link and scroll down to find drivers http://www.motunation.com/forum/viewtop ... 14&t=35607
robleighton22
Mark S wrote:which version? Did you see the driver sticky at the top of this forum?
its not on the driver sticky, and i can't remember the version number. something like version: 3.6.8.x (the one before the latest)
thanks
APADRecordings
Post by APADRecordings »
Hello timmytubby,
I realize you're desperate to get drivers but wanted to let you know that I want and value the new tools. They're incredibly useful. I've already used them to fix a crossover problem in a Cerwin-Vega D32, identify an RCA plug with bad plating acting as a bandpass filter, found a cable with a connector installed wrong and showed a customer who was unhappy with a recording that the problem was with his school auditorium. I can work some magic but a bad room is a bad room! Sometimes a picture is worth dozens of hours of listening! Especially for guys that don't know "how" to listen.
I'm looking forward to using the new tools in a church in Little Rock that has a semi-circular worship center. Performances there are very crowded and I have very restricted space to set up microphones. There is a lot of "comb" effect and these new tools will enable me to a way to minimize those effects.
When you finally get tools like this and begin using them you'll soon wonder how you got along without them!
The driver version before 1410 was 1400 and before that, 1394 - all enable MKIII features but are usable with older gear too. I use 1410 with the original Traveler and an 8Pre.
The struggles everyone has with "drivers" is really an Intel chipset problem with Dual core and Core 2 Duo or more machines, MacIntosh as well as Windows machines. It's pretty clear that Intel has little interest in Firewire but a great deal of interest in Gigabit Ethernet and USB 3.0. I believe Firewire ports will disappear on consumer computers within a year. Firewire will be relegated to special apps for military, etc. USB 3.0 is full duplex vs half-duplex for USB 2.0 but it remains to be seen how well it will work. Intel has not released any real info on it yet. Gigabit Ethernet is packet based but the video guys are using it and commited to it and are solving those problems. A simple $35 Ethernet card with the right drivers will make a super interface. But, we'll have to wait and see how the industry goes.
Mark S
Post by Mark S »
but he's getting a bsod with the new drivers,... All the tools in the world won't help that.
On another topic. How are you syncing your traveler and 8pre? Samplerate/bitdepth?
timmy tubby: I have the old drivers you want. Got a way to get a 15 meg file?
For grins, you might get a tech report started with Motu too.
Gianluca13_2
Post by Gianluca13_2 »
Just to say this last drivers seems to me the most important step forward since the MK3 series born.
It is now one year I own an 828 MK3. I’m always annoyed by strange errors in the MIDI channel. not other issues in the audio part bat a constant type of error with stuck notes or missed notes in MIDI channel. Two days ago I installed this last drivers and also this last problem disappeared. Furthermore the latency seem now returned normal. Compared in two different machine with another firewire interface a Presonus Firebox I obtain same latency time for same buffer length and also at very low latency I don’t notice drop or glitch.
Cheers,
Gianluca
HotShot
Post by HotShot »
timmytubby wrote:So when I saw the new drivers I downloaded and installed them instantly.
Can anyone help?
So what's your situation, now?
What is the error code or message you get at the top and bottom of the BSODs, (maybe something like "Driver_IRQ_Not_Less Or_Equal" or does it name some file?
You didn't give up, did you?
SONAR X1a Producer
tricky
Post by tricky »
Hi guys well after many days of f...ing around with various drivers to get my mk1 MOTU Traveler up and running again, i have at last got it running again by simply installing the original drivers that came on disc with my MK1 Traveler it's now running better than ever cant get it to crash whatever i do, very stable indeed, now then i have a question and i should know this but i dont, when i open my audio device within my DAW i have a choice MOTU ASIO, and MOTU FIREWIRE AUDIO, What is the difference. many thanks
