DP 5.13 / Mac Pro 2.66
Since about a week now, the Masterworks EQ plug-in has disappeared from the drop down menu on the channel strips!
(To make things complicated: there actually is a '(mono)'-symbol in the channel strips menu's now however (that wasn't there before) and clicking that one is able to show a MW EQ, but the plug-in cannot be saved nor re-opened...) I'm puzzled...
Anyone any idea?
Masterworks EQ vanished!
Re: Masterworks EQ vanished!
Hello!
Is your OS in English?
If no, go in the system preferences and change your language to English log out, log on is the MW EQ back?
If yes, you can set back your OS to your original language.
Hope that helps
David
(PS. I have my system in French and I do have this problem often. On my system, it affect proverb as well...
I have build a small script so it clean a cache in the mac OS. On my system it works so I don't need to do the language change... weard)
Hope that helps
David
Digital Performer 11.31 - Mac OS Sonoma 14.6.1
Hi David, thanks.
I tried your tips, but unfortunately this didn't solve the problem at all.
Other ideas someone?
Thanks,
Koen.
Thanks,
Koen.
Sorry to hear that didn't work!
If you can clean the font cache it works on some case.
There are many apps to do that and I use mainmenu to clean the font cache.
Let me know...
David
Let me know...
David
That does the trick + a cold restart.
Many thanks David and a good night to you!
Koen.
Koen.
