64 Bit DP
Tim
Re: 64 Bit DP
Post by Tim »
Are we talking binary?
kassonica
Re: 64 Bit DP
Post by kassonica »
hammerman wrote:I'm holding out for 128 bit. Now THAT will be exciting!
Still won't sound as good a 2" studer and a neve desk, but you'll be able to run 3000 plugins on each track, so that something I suppose......
bootsncats
Re: 64 Bit DP
Post by bootsncats »
flashman wrote:I completely understand the why 64 bit question. I work on film stuff with very large sample loads and massive projects with lots of chunks, 100's of tracks, a total of 10gbs of samples loaded spread over 4 machines and the 32 bit RAM limit is a very real issue. I think to be honest it is a fairly specific group of people who are interested in 64 bit but once Apple let Snow Leopard loose all kinds of things will come along to take advantage of it and within no time there will once again be that great divide. Remember going from OS9 to OSX? PPC to Intel?
amen. and having 64 bit makes working with 64bit plugins less CPU intensive. I have so many tracks when doing a film and so much loaded into ram.
I once did a show in 5.1 live using a combination of many many instruments, samples, pre recorded tracks, ambiances, plug ins up the wazoo. I'm still removing some.
flashman
Re: 64 Bit DP
Post by flashman »
Things just spiral out of control. Just doing a show with loads of stems I've almost run out of buses so what it would be like doing a film with 5.1 stems I dread to think.
kassonica
Re: 64 Bit DP
Post by kassonica »
flashman wrote:Things just spiral out of control. Just doing a show with loads of stems I've almost run out of buses so what it would be like doing a film with 5.1 stems I dread to think.
WTF
You are using near 99 buses???
Timeline
Re: 64 Bit DP
Post by Timeline »
99 busses? That's gota leave a carbon footprint. :D
nick danger
Re: 64 Bit DP
Post by nick danger »
If Scotty can get the Enterprise to warp 13, anything is possible.
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
burn em
Re: 64 Bit DP
Post by burn em »
Tim wrote:Are we talking binary?
You mean library? You know shouldn't talk in the library... :|
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
michkhol
Re: 64 Bit DP
Post by michkhol »
bootsncats wrote: amen. and having 64 bit makes working with 64bit plugins less CPU intensive.
This is not entirely correct. In the 64 bit mode Intel processors have twice as many registers available comparing to the 32 bit mode and in theory it should save some time addressing data in RAM. As for the CPU-intensive tasks like DSP the advantage is not in 64 bits but in less time spent shuffling data back and forth between CPU registers and cache/RAM.
MacPro, 32 GB RAM, Metric Halo ULN8
macOS 13.6.3, DP 11.3
