DP 4.5.2 AND YAMAHA01V96 CONTROLLER
ZENZOMIX
Post by ZENZOMIX »
:cool: HI GUYS .
SOMEBODY WORK DP4.5.2 WITH A YAMAHA 01V96 DIGITAL MIXER AS CONTROLLER SURFACE ?
THIS IS A GOOD SOLUTION FOR CONTROL DP ?
THANKS
bongo_john_uk
Re: DP 4.5.2 AND YAMAHA01V96 CONTROLLER
Post by bongo_john_uk »
Sorry, not tried it in DP but have this working fine with Cubase SX 3. I should have some time over the next two weeks to try it in DP though and will let you know. It was easy in the SX but there are presets on both the 01V96 and in SX so its just a case a few clicks.
In theory its possible with any but I imagine a hold load of configuration unless there are presets available for DP and 01V96. Please anyone watching let me know if there are any before I go nuts for nothing!
I'll post here how I get on later..
What I really would like to do is control effects/synth parameters with the 01V96 faders.. Being able to control the internal mixer in a DAW when you have an external one is not amazingly helpful so far..
Mac Pro 12 core 3 GHz, Motu Ultralite, DP9.1, Mac OS X 10.10.5 64GB Ram.
http://limbicsounds.com
bycas
dp and 01v96
Post by bycas »
ok, not as intuitive as it should be but after yoou do this:
http://www.motu.com/techsupport/technot ... earchterm=
you got to the Control Surface Setup under the Setup menu and select HUI as the driver and the MIDI channel from the device you just created. then, what I did was go to the USER DEF tab of the UTILITY menu on the 01V96 and started assigning DP commands to the user defined keys.
so far I've tryed out: stop, play, rew, ff, rec, rec enable, scrub, and it al works fine, it't rather cool actually
hope I was any help...
byCAS
PowerMac G4 Dual 500MHz, MOTU DP 4.61, MOTU 2408, Yamaha 01V96
