I have the problem of not hearing anything at all.
This is my current setup.
1)Macbook Pro 2.33Ghz 3GB RAM 500GB 7200rpm HDD.
2)MOTU Ultralite MK 3 connected to MBP via Firewire
3) Samson StudioDock 4i active monitors connected to MBP via USB 2.0
4) Kaoss Pad 3 connected to Ultralite MK3 via standard stereo cable ( I have tried each and every input jack)
This is why I get.
-I cant hear nothing at all from the studio monitors despite MK3 receive signal from the Kaoss Pad 3 (I can see that even on the osciloscope)
-When I connect headphones to Kaoss Pad 3 i can hear it normally but when I connect the headphones to Ultralite MK3 i cant hear nothing at all.
When I run the MOTU setup i cannot see the StudioDoc 4i monitors as an output device.
What is what i need??
I need the StudioDock to be my main stereo output. Should I need to plug cables from the ultralite to the studiodock input RCAs??
Is there a way to setup the software to use the USB connection to setup the monitors to be the ultralite main output?
thank you very much in advance
Noob with not sound at all (bad routing of course i guess)
