828 MK3 as a live mixer - wazzup widdat?
Rumpl4skn
Post by Rumpl4skn »
First, let me establish my credentials - I'm a professional in-ear monitor mixer for an artist on RCA records, so I know digital mixing. I've been trying to use my 828MK3 as a live digital mixer for a cover band, and I'm about to blow my brains out.
1st problem - I cannot get audio out of the Main Outs unless it is assigned to Analog 1-2 (or 3-4 thru 7-8). Assigning it to Main Mix is dead air, even though the meters say signal is going there. I was under the impression (from the manual) that there are 5 sets of stereo mixes available - Main, An1-2, An3-4, An5-6 and An 7-8. If Mains are a derivative of one of the Analog mixes, then I understand (but that screws the pooch for me, as I need a main mix plus 4 stereo ear mixes.) But if so, why can you dial up a separate Mains mix in CueMix if it's related to an Analog one? Doesn't make sense.
2nd problem (and this violates a basic rule of audio) - I have a hand held mic plugged into Mic 1 jack, and even with the Trim pot turned to ZERO, I still get full volume. The trim will ADD some level if turned up, but it never gets anywhere near OFF. If this is a head amp gain pot, turning it to ZERO should KILL that mic signal EVERYWHERE. So this is baffling me.
Thanks for any suggestions with these issues.
Nuendo 3
Athlon +4400 Dual Core
Hammerfall RME 9652
And the will to go where everyone has gone before.
Rumpl4skn
Re: 828 MK3 as a live mixer - wazzup widdat?
Post by Rumpl4skn »
Okay, I saw here in the forum that there were some issues with the old drivers, so I got the latest driver, and tried the Update program. I hold in Page and power up, but the updater says "no units in update stage". So, despite the fact that the unit generally works, the updater is not finding it.
Things get curiouser and curiouser.
This laptop is running WIndows XP Pro, btw. Forgot to mention that.
Nuendo 3
Hammerfall RME 9652
HotShot
Post by HotShot »
There is an issue with the new driver, 3.6.8.1400. where ASIO output routing is offset, in which Main Out is Analog Out 1-2. Analog Output 1-2 is Analog Output 3-4. etc.
I don't know if this issue affects all MK3 products, but I have it with my UltraLite-mk3. MOTU tech support says they're working to fix the issue.
The 3.6.8.1394 driver doesn't have the ASIO output offset problem. It can be downloaded from here: http://babelfish.yahoo.com/translate_ur ... =yfp-t-501
I believe the 828-mk3 have pad switches on the front panel. These switches are for reducing a hot signal coming into the Mic/Instrument inputs, if neccessary, by -18db and -36db (as the switches have 3 positions. down, middle, and up). That's how they work on my unit. You might want to use those pads.
May a song always touch you in a possitive way!
SONAR X1a Producer
Windows 7 Pro 64-Bit
Intel Core i7 920, Gigabyte EX58-UD5, ATI Radeon HD 5770
MOTU UltraLite MK3, Delta 1010LT, KeyStation Pro 88, Shure KSM27, 6GB 1600MHz DDR3, 160GB, 350 GB 7200rpm HDDs, QSC K12s, Numark DDS80
Rumpl4skn
Post by Rumpl4skn »
Thanks HS. I believe the driver issue may be the problem, but now my problem is the non functional update. I wonder if anyone else here has had that problem as well, I didn't find it on a search of the forum's topics.
Thanks again.
EDIT: Problem resolved. Had to hook it to another system to do the update, and now the driver is working great. Funny that MOTU doesn't seem to have drivers listed on their downloads page..... very odd.
Nuendo 3
Hammerfall RME 9652
