MAchfive AU
MAchfive AU
I need DP to read Machfive AU instead of MAS,AU is already in the plug-in folder but I need the AU search to locate it,any help would be awsome.
Just testing this thing out
Re: MAchfive AU
cant be done, this have been making me angry with mach 5 and MX4, I want to use the AU version with automap but cannot, when a motu plugin is installed in DP it will only read the MAS version, the part that makes me certain that it is with motu plugs only is that my wave arts appear as both MAS and AU.
send a techlink to motu to complain about this, the more they get the faster they'll change it.
Mac Pro 2X Dual Core 2.66Ghz-10.4.9-7 GigRam-828MKII-MTPAV-Ultralight MK3-Digi Performer6.01-PeakPro5.1-Reason4-AbeltonLive6-Virus Rack(Red)-ReMOTE 25 & 37 SL-Nocturn-Stanton Dacratch-PluggoPack-DimensionLE W/EmuProteusPack-Sylenth1-Discovery MAC-MX4-Rapture-Alpha-Octopuss-Automat-Automat1-TALbassline-TALUno60
Re: MAchfive AU
I actually had a au and mas version in the past running just fine side by side but cant get it going now.
Re: MAchfive AU
Are you on DP6? If you check in Preferences>Audio Plugins you will find the 2 versions and maybe one is checked and the other is not.
In mine there is one listed in the first part of the list with all the MAS plugs, and another with the AU plugs (listed as Duplicate)
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Re: MAchfive AU
mine shows the au as a duplicate in plug in prefs but will not allow me to activate it, I can check the little box and enable, but when I'm up and running the AU, nor the automap version of it will appear in my VI selection menu.
Re: MAchfive AU
In Preferences if you uncheck the MAS version and check the AU version, when the audio engine restarts the AU version is definitely running.... I proved it as I just removed the MAS version from my plugins folder..
It seems you can have one or the other, just not both showing up at the same time.
Cheers
Stephen
Cheers
Stephen
Re: MAchfive AU
thank you sir.
Re: MAchfive AU
it runs, but I sure nuff can't get no sound out of it.stephentayler wrote:In Preferences if you uncheck the MAS version and check the AU version, when the audio engine restarts the AU version is definitely running.... I proved it as I just removed the MAS version from my plugins folder..
Cheers
Stephen
Re: MAchfive AU
Cheers
Stephen
this worked on Mach 5, not on MX4, but thanks though.
