DP au search
Akai96
DP au search
Post by Akai96 »
Hello all.Here is the deal,I need to load machfive as au instead of mas. But there is already a au version in the plug-in folder,how do I get DP to au search again? any help would be very gratefull.
Just testing this thing out
Kubi
Re: DP au search
Post by Kubi »
Remove or trash the following file: user/Library/Preferences/Digital Performer/Audio Unit Info Cache
Then start up DP - it will scan your components folder again.
You will also need to remove the MAS version of MachFive from the MAS plug-in folder (and i.e. hide it in your Documents folder or something), otherwise DP will always pick the MAS over the AU.
Any particular reason you want to use the AU version? MAS works great here.
jarok
Re: DP au search
Post by jarok »
Hi
You can trash Audio Unit Info Cache found in:
User Library > Preferences > Digital Performer™ > Audio Unit Info Cache
jarok
http://www.facebook.com/pages/Trio-Trout/140467307206" onclick="window.open(this.href);return false;
Frodo
Re: DP au search
Post by Frodo »
I think if you just remove the MAS bundle, DP will scan/cache the AU version the next time you boot (won't it?).
Oh, well. I guess if it doesn't, removing the AU Info Cache is always a good idea.
Akai96
Re: DP au search
Post by Akai96 »
Kubi wrote:Remove or trash the following file: user/Library/Preferences/Digital Performer/Audio Unit Info Cache
The AU version locks better with my 3rd party VI's,anyways thanks a lot!
Akai96
Re: DP au search
Post by Akai96 »
Tried it,it still won't recognize the AU Version.any idea what might be wrong? :?
thracks
Re: DP au search
Post by thracks »
Mach V will only load as MAS in DP. The AU version is for other non MAS hosts such as Logic or Ableton Live.
Steve
2020 Mac Mini | Sonoma | 828x |
