Output metering on the left side face of the unit only shows in the odd-number channels. So if I have a stereo output on 1&2 analog outputs, I only see output signal on 1 in the left panel for the 3 banks of 8 channels. If I switch to metering on the right side of the display I can see the input and output correctly.
In CueMix I see no metering in the Mix bus or the Out bus even when I have routed input signal to a bus. Furthermore there is no control of output level what-so-ever.
I need to set up 5.1 surround monitoring and lower the level of the rear speakers for calibration of the system. This can only be done in CueMix but the faders in CuemIx do not affect the output gain.
In Sonar (and in most other DAWS) you can not control individual levels in a surround buss. For instance if I send a surround signal to the surround bus I cannot lower just the rear signals alone.
Any suggestions (other than buying a hardware controller!
Best,
Hendrik
