Perhaps some one here has this issue or a resolution for it ...
I'm using Sonar 8.3.1 Producer Edition. I'm trying to use the BPM Sampler (plugin) with BPM. I've followed the instructions to a T (it's not rocket science) and have watched some videos on YouTube showing the procedure; but to state the situaion:
I insert BPM as usual in the Synth Rack (btw, BPM is working just fine in all other manner with version 1.0.2).
I insert BPM Sampler in the FX bin of an audio track.
I hit Play and the BPM Sampler meters show proper activity and levels so I know signal is getting there.
THen I bring up BPM and select the sampler as the "source", then I click the CLIP button, and again choose the Sampler as the source.
I start playback in Sonar - all meters look good in Sampler, and sound fine.
When I click RECORD in the clip window, another window pops up and starts scrolling a message that it can't load the "Tempx.wav" file (where x is a number).
So I try the same thing but using the Pad. I select a pad, then click on the record button in BPM at the top, and sampler shows fine metering, but no sample gets recorded.
If anyone can confirm they are using the BPM sampler/BPM combo successfully in Sonar 8.x and, if you are, tell me what I'm doing wrong? (I'm sure I"m following the correct procedure, but ya never know).
I've put in a tech ticket at MOTU, but that could take a week
Thanks in advance for any feedback/help.
