2 bar button click hiccups
ovaltine52
Post by ovaltine52 »
Got 6.0.2. Started a project, lay down kick, 2 bar button on, then on the 1st "real" bar beat 1 clicks, stops, a very erratic 3 & 4, then straightens itself by the 2nd real bar. It does this no matter where I start whether record/playback. 2 bar button OFF, everything's normal, no jumpy click in the 1st bar/where ever the cursor's at.
Anyone else had this problem? How to fix?
chrispaulson
Re: 2 bar button click hiccups
Post by chrispaulson »
I'm having a similar problem with 6.02, after the count in, the click drops out for the first measure and then comes back, anybody have some advice on how to fix this problem? Thanks
Chris
mfromwhere
Post by mfromwhere »
Same problem here.
Mac Pro (Late 2013)
MacOS 12.7.5
DP 11.31
Symphony I/o MkII
NI Komplete Kontrol s61
ovaltine52
I did hear back from MOTU & it is an issue with 6.0.2, to be addressed in the next update. So that's that.
Now, since I'm still a bit of a newbie, I wanted to make sure I knew what I was talking about before I suggested this workaround a friend suggested though he didn't remember exactly how he does this. I got it:
Go to PROJECT menu>MODIFY CONDUCTOR TRACK>INSERT MEASURES. Then tell it how many measures to insert. If you check the box, "Maintain all times following the insertion point", it will put meas. 0,-1, -2, etc. which is the desired effect I want. Leave the box unchecked, it renumbers the meas. starting with the 1st of your newest measures as bar 1.
Having those "negative" measures is better for me anyway since I may "change my mind" & decide I want some pickups to the original bar 1, or also in my case, with the 2 bar button ON if I don't "nail" the downbeat of real bar 1 I get sound cut off, blip, etc.
So over here, better to use the "negative" bars anyway, though yeah, MOTU should fix the 2 bar warning.
Hope this helps.
fsheinfeld
Post by fsheinfeld »
Same problem here, but this has been an issue for me since DP 5.
ovaltine52
Interesting. Didn't have this issue in 5.
Yep, need to fix.
