I'm gonna lay my problem down here at the MOTU forum, because I am so frustrated and I'm out of ideas!
The thing is: I have a DAW running Windows Vista Home Premium x64. It's running Cubase 5. No matter what settings I choose for my MOTU 24IO, I get crackles and pops all over the place. I'm using the MOTU ASIO driver. Normally with a system like mine, you would be able to choose a buffer setting of 256 or lower even, without any hassle. When I choose a buffer setting of 1024 or lower, I get crackles, dropouts and distortion. Even if I lay down just one audio track with 1 sample!!!
I tried almost everything with no difference:
- Installing Windows XP, Windows Vista x86 (same thing happens)
- Applying various tweaks
- Updating all of my device drivers to the latest version
- Choose AHCI mode from the BIOS in stead of emulated PATA mode
- Raising the voltage of my memory a bit
- Perform a error checking test of my hard drives
- Setting the power options to best performance
- Moving the page file to a different hard drive
- Set processing to background tasks
My DAW is a computer with the following specs:
- Asus A8R-MVP Deluxe motherboard (ATI Xpress 3200 chipset, Uli M5229 PCI Bus Master IDE Controller)
- AMD Athlon X2 4600+ CPU
- 4GB OCZ PC4000 DDR Memory
- 2 Western Digital Raptor 150GB SATA 2 Hard drives for system
- 2 Western Digital Caviar 250GB SATA 2 Hard drives for audio files and projects
- Plextor DVD/CD Burners
- Asus Ati HD2400 PCI-e graphics card
When I just play an audio file in Windows Media Player, everything is fine. I have no more options. Do you guys have any idea what is going on? I would be very thankful
