Hi,
I recently bought a 828 Mk3 and I am having a bit of trouble ironing out a couple of small problems.
1) Whenever I select a sample rate higher than 48 I am unable to select my phones output to "phones". This option completely dissapears. Is this normal?
2) when I connect a guitar to the mic input I get no input signal detected on the front display. I have un-muted the input in the selected mix and played around with the gain but no change.
Any ideas greatly appreciated
Paul.
New to 828 Mk3. Couple of questions.
Re: New to 828 Mk3. Couple of questions.
@1. I cannot reproduce this now,
@2. Did you switch to Instrument on the front panel?
greets
yeti
greets
yeti
Hi,
thanks for the reply. It turns out that the mic input is faulty and I am sending the unit back.
Before I do can anyone who owns a 828 mk3 confirm that you should be able to select phones output to phones when the sample rate is above 48?
thanks
Paul
thanks
Paul
