2x 896HD on Vista 64 won't synchronize
lemon
Post by lemon »
Hi folks!
I use Vista 64 for a while now and have always worked with one 896HD only and without problems. Yesterday I wanted to check my DAW including the 2 896HD I own and I noticed that the 896HD will synchronize but only for a few seconds, then the synchronization process (blinking LEDs on both) will start again. Obviously the sequencer won't work properly then.
The first 896HD is connected via firewire to my TI-chipset-Firewire-Card on my PC, the second one is also connected via firewire to the first one. I've set the buffers up to 2096, but that didn't change anything.
Anyone a hint? Is this a known Vista 64-problem?
Thank you!
Lemon
TheRealRoach
Re: 2x 896HD on Vista 64 won't synchronize
Post by TheRealRoach »
This is a Microsoft Windows issues, regardless of XP or Vista.
Read the first post for the XP fix here:
http://www.motunation.com/forum/viewtop ... 14&t=31518
Read this whole thread for some ongoing developments with regards to Vista:
http://www.motunation.com/forum/viewtop ... 14&t=34558
Be sure to report back with your findings.
Mike Rocha
http://www.mikerocha.ca
Custom ADK, Quad 3.0ghz, 4gig ram, Win7 64-bit, Motu 3.6.7.3 x64 drivers
Macbook Pro 13" touchbar, High Sierra, 73220 drivers
Motu 896 x 4
