6.02 sequence editor graphic bug?
Noticing that when minimizing track height in the sequence editor that they will usually not collapse to a fully minimized size with the usual shortcut commands, and it seems to vary as to what size will be 'maximum minimization' in any given session. If I want everything as small as possible, enabling the 'all tracks' group seems to be the only thing that will let me manually drag it all to smallest size. Never saw this before 6. Anyone else?
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
Re: 6.02 sequence editor graphic bug?
Well, it was there in 6.0 as well; sorry to hear it isn't fixed yet.
My solution has been to zoom everything larger/taller by a few degrees CMD + page up) and then collapse the tracks back down and they seem to squish up more completely.
What I want to know is what does 6.02 fix?
MacBook/828mkII/Traveler/Event 20/20bas
White MacBook 2GHz C2D, 2 GB Ram, Traveler, 828mkII, DP7.22, LogicExpress 9
- FMiguelez
In DP 6.01, if I press Command-Option-Down arrow everything gets as small (or large with up arrow) as possible. Works fine here... Is that the command you mean by "the usual shortcut commands"?
Command-Down for scaling doesn't go all the way down to smallest size anymore, or consistently to any particular size. I never use Command-Option-Down; that does seem to go all the way with no scaling.
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
- kassonica
Does on my setup?EMRR wrote:Command-Down for scaling doesn't go all the way down to smallest size anymore, or consistently to any particular size. I never use Command-Option-Down; that does seem to go all the way with no scaling.
Strange very strange....
I'm not getting it on MBP or G5. Could it be something silly like saved state size in a template?
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
