mixing pro tools session in DP
- HLStudios
i have a client who lives in another city and wants me to mix his tracks in my studio..
h recorded it in another studio using PT7 and currently he has the pro tools session backups and is going to send them to me...
i know in order for me to open it, it has to be OMF format..is there an applicationi can use to convert it to OMF without actually opening the session in pro tools and exporting it??? he has no access to pro tools so he cant export the WAV files...anyone help???
PowerMac PPC G5 Dual Processor 2.0Ghz 4GB RAM 720GB HD OSX 10.5.7 (Leopard)
MOTU 424 PCI-X Card / MOTU 2408 MKIII / Focusrite Octopre / M-Audio Axiom 61 / TC Electronic Finalizer / M-Box
Digital Performer 6.02 / Pro Tools 8 / Peak Pro 5 / Reason 4 / BFD 1.5 / Addictive Drums / Antares Auto-tune /
Nomad Factory Analog Sign. Pack / PSP Audioware / Voxengo / Sonalksis / Celemony Melodyne / T-Racks 3
a pair of acoustic guitars and basses..lots of creativity!!
- Mr_Clifford
Re: mixing pro tools session in DP
DigiTranslatorHLStudios wrote:.is there an applicationi can use to convert it to OMF without actually opening the session in pro tools and exporting it???
Or... if he sends you the Pro Tools session folder, you might be able to just import the audio files directly into DP. As long as the track names are labelled systematically (PT's auto naming is very good) and there aren't too many files on each track it should be possible. The timestamps will tell DP where to put the files on the timeline. This won't really be an option if there was lot's of editing/moving etc. within ProTools after the recording and the edits weren't consolodated.he has no access to pro tools so he cant export the WAV files...anyone help???
Your best bet is to find someone with PT and Digitranslator. Then you can import the sessions into DP with all the regions and edits intact, which more often than not is vital. Although OMF import into DP is pretty flakey, I would try that route first.
How many songs?
- vbassguy
You know, I keep a PT le rig in my studio for this very reason. I don't record to it. I don't mix with it. I simply open any PT session sent here and ready it to move over to my trusty DP environment. I have found this to be a cost effective approach. If my clientele requires a PT session when I am finished
with my work- I move it back over to PT. Everybody's happy.
G5 quad 2.5 ghz w/ 8 gigs ram, OS 10.5.4, DP 5.13,DP6, Mach 5,Mach 5 v2, SI, two loaded UAD-1e cards, PCIe 424, two Black Lion Modded 24 I/O's, Harrison 3624 console, cool old mics, pre's and compressors.....Great sounding Rooms.........
www.RRRPROD.com
www.RRRPROD.com
I have an HD3 rig for the same reason.
Someone sent me a PT session recently that had no time stamps on WAV files; do they have to be manually written in PT? Did they forget during merging and export? I had to email the PT session, sans audio files, to someone who could take a million screen captures showing exact sample location of file beginnings, and build it manually.
Doug Williams
Tape Op issue 73
DP 11.34
Studio M1 Max OS12.7.6
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.34
- Mr_Clifford
Did you drag the audio files into the track list in DP6.02? - That's a glitch in DP6.02. I thought the same thing recently with audio files I was bringing in from a Pro Tools recording session, until I discovered that if I imported the audio files via the 'import audio' dialog box the timestamps came in fine. In Pro Tools using Broadcast Wave, the timestamps are written automatically into the file (unlike SDII). Pro Tools has always been really solid with timestamping, unlike DP, unfortunately, which has been flakey since DP5.12 in this regard.EMRR wrote:Someone sent me a PT session recently that had no time stamps on WAV files; do they have to be manually written in PT? Did they forget during merging and export? I had to email the PT session, sans audio files, to someone who could take a million screen captures showing exact sample location of file beginnings, and build it manually.
Golden Info!Mr_Clifford wrote:Did you drag the audio files into the track list in DP6.02? - That's a glitch in DP6.02. I thought the same thing recently with audio files I was bringing in from a Pro Tools recording session, until I discovered that if I imported the audio files via the 'import audio' dialog box the timestamps came in fine. In Pro Tools using Broadcast Wave, the timestamps are written automatically into the file (unlike SDII). Pro Tools has always been really solid with timestamping, unlike DP, unfortunately, which has been flakey since DP5.12 in this regard.EMRR wrote:Someone sent me a PT session recently that had no time stamps on WAV files; do they have to be manually written in PT? Did they forget during merging and export? I had to email the PT session, sans audio files, to someone who could take a million screen captures showing exact sample location of file beginnings, and build it manually.
Have client consolidate his PT tracks to 1:00:00. Now just import and all tracks should audio tracks will line up in any DAW.
http:www.davidosuna.com
Mr_Clifford wrote: Did you drag the audio files into the track list in DP6.02? - That's a glitch in DP6.02. I thought the same thing recently with audio files I was bringing in from a Pro Tools recording session, until I discovered that if I imported the audio files via the 'import audio' dialog box the timestamps came in fine. In Pro Tools using Broadcast Wave, the timestamps are written automatically into the file (unlike SDII). Pro Tools has always been really solid with timestamping, unlike DP, unfortunately, which has been flakey since DP5.12 in this regard.
Interesting. I did actually use the import method, as I was searching for the correct formatting which would avoid conversions. No stamps. I'll have to try it several more times and see if the results change.
Doug Williams
Tape Op issue 73
DP 11.34
Tape Op issue 73
DP 11.34
- Timeline
What he said.dosuna11 wrote:Golden Info!Mr_Clifford wrote:Did you drag the audio files into the track list in DP6.02? - That's a glitch in DP6.02. I thought the same thing recently with audio files I was bringing in from a Pro Tools recording session, until I discovered that if I imported the audio files via the 'import audio' dialog box the timestamps came in fine. In Pro Tools using Broadcast Wave, the timestamps are written automatically into the file (unlike SDII). Pro Tools has always been really solid with timestamping, unlike DP, unfortunately, which has been flakey since DP5.12 in this regard.EMRR wrote:Someone sent me a PT session recently that had no time stamps on WAV files; do they have to be manually written in PT? Did they forget during merging and export? I had to email the PT session, sans audio files, to someone who could take a million screen captures showing exact sample location of file beginnings, and build it manually.
I have never seen a PT session with .wav files that did not have timestamps. .AiF, yes, .wav no.EMRR wrote:Someone sent me a PT session recently that had no time stamps on WAV files; do they have to be manually written in PT? Did they forget during merging and export? I had to email the PT session, sans audio files, to someone who could take a million screen captures showing exact sample location of file beginnings, and build it manually.
The easy solution likely would have been to create a new, blank session, and use IMPORT SESSION DATA to import all the tracks from the session in question. But prior to doing this, go to PREFERENCES, then to "Processing", and check the checkbox next to "Convert Imported .wav Files to AES31/Broadcast Wave". The imported files would then be assigned timestamps upon import. But as I said, I have never seen a .wav file in PT without a timestamp, so I would check further to see if there is something else amiss.
