James Steele wrote:In a way, my adventures with this lead me to consider that for someone like myself who doesn't use a lot of VIs, this is probably not something I need to worry about and is really more the province of the heavyweight composers here doing orchestral mockups where your VIs and complex libraries place far more demands on a computer than guys like me doing guitar-oriented rock with a few VIs thrown in here and there for spice.
In my experience, I would say, only go out of DP if you absolutely have to. The most common reasons:
-need more RAM access (use something like Bidule or external computer)
-maxing out CPU (need more computers)
-you can't afford to wait for large template sessions to load between projects because of really tight deadlines (use something like Bidule or external computer)
-need access to apps or plugins that don't work in DP (ie. VST)
-needs access to apps or plugins that don't work on Mac (ie. Giga)
-need a platform that will always work and is immune to compatibility issues regardless of how you upgrade your DAW and plugins. For example, in the last 5 years, I've gone through 3 Macs, 2 main OS versions plus lots of OS updates, endless versions of DP, DSP plugins from Waves, Spectra and others. However, I've NEVER EVER EVER touched my Giga pc in 5 years-----EVER----in any way. And the same goes for my VSTack pc. All I do is add sounds to them and pray they don't break. And now that Giga is dead, I pray even harder. Heck, I'm still on 10.4.11 and DP5.13 on my Mac because I'm scared of what I have to face with Leopard and DP6. I've been trying with DP6 with limited success, as is documented in another thread (
http://www.motunation.com/forum/viewtop ... =1&t=34410 ). At this point I think I'm just going to skip Leopard and go straight to Snow Leopard someday in the distant future.
-you enjoy self torture. Being your own multi-OS IT guy excites you; especially having to figure out pc/Giga problems!
The fact is in 2009, Macs are MASSIVELY powerful, if you can afford a current computer. In most cases, I'd say that a single computer and DAW can handle just about any music writing situation for rock, pop, jazz, R&B, general synth/sample based drama, anything live recorded that needs to be mixed and even most basic orchestral mockup situations. It's the small % of people that have the massive mockups and every commercial orchestral release, plus private sampling sessions and work on nasty deadlines that require reaching beyond the DAW. The fact is that DP is REALLY powerful and capable.
Here's my advice----I'd say stay inside your DAW as much as you can. Then once you have to venture out of DP, EMBRACE IT FULLY. Don't half-a$$ your external setup whatever it is, because you'll suffer and then it will be way worse than if you spent the time making a nice way of working with external stuff.
Look at Mike's videos------everyone is amazed by his templates and how fast it allows him to work. That's because he spent a LOT of time setting it up in a way that works for HIM. (And don't forget he's a fantastic keyboard player with I'm sure lots of theory under his belt.) I've made templates like that too; and mine work well for me. And now because of Bidule, I'm in the middle of doing it again. And when Kontakt 3.5 comes out that can supposedly access a TON of RAM, then all of us with templates will explore redoing them again......and then when LA Scoring Strings (LASS) comes out, we'll all be doing it AGAIN. I know beta-testers of LASS (I don't test it) that have completely redone their templates because of it.....it's endless.
Anyway, there's my humble two cents.
Thanks again to Mike for starting all these conversations.
Cheers.
-gabe
Computer: 2019 Mac Pro 28-core 2.5gHz, OS 10.15.2, 96GB ram, all SSD/NVME drives, MH Labs ULN-8, MOTU MidiTimepiece AV
DP Setup: DP10.11, all Spectrasonics VIs, all Waves plugins, Sonnox AU, Altiverb, NI Komplete 12/K5+6, Plogue Bidule 64 as VI host
