MOTU Universal Audio Install- OSX, 1.4.20
Klaus
Re: MOTU Universal Audio Install- OSX, 1.4.20
Post by Klaus »
stephentayler wrote:This is what it says on the first page of the installer
FFT and Spectrogram display
for the mk3 series of MOTU Firewire Audio Interfaces
cheers
Stephen
Question :
Do these new features take much power away on the dsp ?
can one see that on the dsp meter ?
Or only when these new features are engaged ?
Klaus
carrythebanner
Post by carrythebanner »
rcmusic wrote:1.4.20 came back on march the 11st ?? can omeone explain or tel if something has changed. thanx
An oscilloscope:
http://www.motu.com/newsitems/new-audio ... face-users
1nput0utput
Post by 1nput0utput »
I'm fairly sure that the signal analysis displays use the computer's CPU, not the interface's DSP. Open the oscilloscope window while viewing the spectrogram and FFT analysis on a pair of channels. The DSP meter level doesn't change.
Klaus
Post by Klaus »
Thanks 1nput0utput for this info
and best regards
Klaus
dewdman42
Post by dewdman42 »
Ever since I installed this version of the driver, all I get is high pitched beeps in all software I use, except for DP. DP works perfectly. Everything else produces nothing but errors. I unfortunately don't have the previous driver saved here either.
dewdman42 wrote:Ever since I installed this version of the driver, all I get is high pitched beeps in all software I use, except for DP. DP works perfectly. Everything else produces nothing but errors. I unfortunately don't have the previous driver saved here either.
Try this:
http://www.versiontracker.com/dyn/moreinfo/macosx/15637
dewdman42
Post by dewdman42 »
Thanks for that. I tried rolling back to 1.4.9 and still having same problem. Hmm, I am not sure what version I was using before. I had not updated it for a while, so its probably a few versions back that it was working. However I can't seem to figure out how to get those older versions from version tracker. Their links just keep going to motu's site and only showing the most current version, 1.4.20
Is nobody else experiencing this problem?
Klaus
Post by Klaus »
I don't think it is from the driver, sounds more like to much FW traffic resulting in the high tone...
Klaus
dewdman42
Post by dewdman42 »
The traveler works perfectly when I use Digital Performer. When I use any other audio application, it creates nothing but spaced out high pitched beeps. I've tried a number of standalone synths, including from NI and others, as well as Reaper and EnergyXT. None of them work with the traveler, but if I crank up DP, it works perfectly.
The other apps were all working perfectly a while back also. I can't really remember when was the last time they worked because I've mostly been working with DP for a while. But they did work before. It could have been a driver update. Maybe could have been update to 10.5.6, I really have no idea what else. All I know is that DP is the only app that can use the Traveler now. Everything else has to go through built-in speaker until I figure this out.
dewdman42
Post by dewdman42 »
I found a solution, in case anyone in the future is having this problem:
According to what I found out from a Logic forum post, someone was having similar problems and MOTU instructed them to go into the MOTU Audio Setup dialog and change the Optical Output to None, then to ADAT, then back to None again.
I tried it and that fixed the problem completely.
dewdman42 wrote:I found a solution, in case anyone in the future is having this problem:
Wow. Thanks for posting this. Who'd a thunk it? The $75 check is in the mail :wink: .
jr213
Post by jr213 »
NO FREAKIN' WAY!!! THANK YOU FOR POSTING THIS!!!!!
It's been driving me completely NUTS for months, but I've been too busy to troubleshoot, so I've been bringing audio in from the out on my Mac into Analog 7-8 to monitor other software. This deserves a sticky, IMO, as it was hard to find. Thanks a TRILLION!!!
DP6.02, OSX.5.latest on Quad 2.66GHz MacPro w/ 3GB RAM, MOTU 828mkII, UAD-2 Duo, Altiverb, PSP, TriTone, Omnisphere, Komplete 5
