What is the difference between mk2 and mk3
What is the difference between the 2408mk2 and the 2408mk3?
Re: What is the difference between mk2 and mk3
Plus one.
- BradLyons
- Primary DAW OS: Windows
From the I/O point of view, I "believe" there was an upgrade in the converters. I don't know if that was the official answer off the top of my head, but I had both and the mk3 did sound better. A major difference when purchasing the core is the difference in the PCI324 and PCI424 cards. The 324 had (3) connection ports while the 424 had (4), however the PCI424 also had DSP processing onboard for latency-free monitoring where the 324 card did not.
Thank you,
Brad Lyons
db AUDIO & VIDEO
-Systems Advisor, CTS
Brad Lyons
db AUDIO & VIDEO
The PCI-324 has this feature also but the CueMix features aren't available under Mac OS X, and the PCI-324 generally isn't compatible with most newer computers running Windows.BradLyons wrote:… however the PCI424 also had DSP processing onboard for latency-free monitoring where the 324 card did not.
- BradLyons
Hmmmmm was I actually wrong for a change?1nput0utput wrote:The PCI-324 has this feature also but the CueMix features aren't available under Mac OS X, and the PCI-324 generally isn't compatible with most newer computers running Windows.BradLyons wrote:… however the PCI424 also had DSP processing onboard for latency-free monitoring where the 324 card did not.
Thank you,
Brad Lyons
db AUDIO & VIDEO
Brad Lyons
db AUDIO & VIDEO
Are they both 24 bit?
do they both go to 96k?
