828MK3, Size of CueFx window
chsimy
Post by chsimy »
Hello,
anybody knows how i can increase the Cue FX window
to the full width of my monitor to see more channels ?
(with the mouse on the bottom right edge it didn't work)
My System:
Windows XP Pro SP3
Motu 828Mk3
Thanks !!!
Simon
XYZ
Re: 828MK3, Size of CueFx window
Post by XYZ »
Hmm. This is the way to do it. It works for me. It will get wider if you change all the tracks from stereo to mono, but this definitely works for me. Can you shrink it with the lower right hand corner?
MacPro2.66/3GB/828mk3/Rosetta800/UAD-2Quad/Waves/
XYZ wrote:Hmm. This is the way to do it. It works for me. It will get wider if you change all the tracks from stereo to mono, but this definitely works for me. Can you shrink it with the lower right hand corner?
XYZ are you using Windows? From your sig it says Mac. Maybe it's different on a Window system and the bug just affects Windows?
XYZ
Post by XYZ »
That could be it. Dr. Steele!
pcournoyer
Post by pcournoyer »
I'm on XP SP2 and it resizes. It did not work before so perhaps check your version. I have 3.6.8.1360 (which display as 3.6.8.1659 in the MOTU console). Note that the cursor does not change, so you do not get the usual visual feedback. But if you drag the lower right corner, it works nonetheless.
