Tascam 428 should work in DP ?
Aramis
Post by Aramis »
Hello All Tascam users !!!!
Magic Dave is telling me the Tascam 428 should work with DigitalPerformer 6.0 !!!!!!
I miss something !!!
Mine Does not work at all !
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
dirty penguin
Re: Tascam 428 should work in DP ?
Post by dirty penguin »
I used to use an 828 with dp 3 no problem. Worked quite well.
G5 PPC 2X2 Ghz,OSX 10.5, DP 7.1, 2408 MKII. Mach 5 v2, EZ Drummer, Reason, NI Komplete.
Aramis
Post by Aramis »
I am sorry , I forgot to mention the version !
6.1
dirty penguin wrote:I used to use an 828 with dp 3 no problem. Worked quite well.
glitch
Post by glitch »
I'm running 10.4.11 with DP 6.02 and my US-428 works perfectly. I'm running the latest Tascam driver (3.40) thats available in their Legacy link.
I just installed 10.5.6 on a partition and will let you know how that runs
"so this MOTU tech walks out of a bar...."
Subscriber to the 'Mac-Of-The-Month Club' (with UberEats delivery package)
Aramis
Post by Aramis »
Wow !
Maybe you will be my salvator !
glitch wrote:I'm running 10.4.11 with DP 6.02 and my US-428 works perfectly. I'm running the latest Tascam driver (3.40) thats available in their Legacy link.
Aramis
Post by Aramis »
Hello again , I did a remove software with the 828 powered off and install again with power off and niet !!!!!
And it is 3.40 !!!!!
I do not see it appeer in the controler stuff !
I see the audio part !
I see the MIDI device for it .
But I do not see the controler !!!!
gr!!!!!!!!!!!
Aramis
glitch
Post by glitch »
Did you look under the Setup Menu for Control Surfaces. I added it there and it's fully functional. BUT,... I still have yet to set it up on my MacMini running 10.5.6 (the true test). I probably wont be able to get to this till next week. I'm currently trying to configure my Ozonic.
Aramis
Post by Aramis »
Yes , I did and it does not appear there .
glitch wrote:Did you look under the Setup Menu for Control Surfaces. I added it there and it's fully functional. BUT,... I still have yet to set it up on my MacMini running 10.5.6 (the true test). I probably wont be able to get to this till next week. I'm currently trying to configure my Ozonic.
Aramis
Post by Aramis »
Hello Glitch !
I got an idea !!! Do you think you could send me your Motu Control Surface content zipped or else ?
There is the us428.bundle file which is 76 ko here and look different than the MackieControl one to me .Who knows ?
Aramis
