How do you get loop points to save in a preset? I've created a sample and I'm trying to make it into a preset. I set up the loop, everything appears to be fine, I save the preset and sample. Close Mach5 and re-open and then open up my preset. The sample is there, but the loop is not.
I managed to do it once and the loop stay on re-opening but can't repeat it. The manual is of no help.
Anyone? Is this a bug or what?
Loops don't save
Re: Loops don't save
Just happen to come across the same problem today: Loops with or without crossfades don't save!
With a few tries I found out , it happens only if I use SDS2 files - via drag and drop within DP 5.13 . As soon as the files are converted to Aiffs and then dragged into M5, it works, the loops are saved.
But: this should not be! SDS2 is Motus native audio format - or has been until now ( a.f.a.I.k. DP 6 works with many formats )
So when smples get dragges into Mach5 from within DP , we have a problem with our loops!
Anyone else come across this problem? ( Ist reliably repeatable)
MacPro 2x 2g, 3g ram, 10.58 & 10.62, TC Studiokonnekt 48, Focusrite Octopre, Powercore PCIe, Mach Five2, MSI, Real Git, EMU MP7,Selmer Tenor Sax, Yamaha Flute, Yanagisawa Soprano Sax, Wooden Flutes, handbuilt Tamburas, lots of imagination, frequently of my rocker...
Volker
Volker
