Miroslav Philharmonik Multi Output?
marcushane
Post by marcushane »
Does anyone know if it's possible for Miro to do Multi Outputs like Kontakt so that I can just my record audio when I am ready for Mixing. The bundles window indicates that it sees the outputs but the Plug itself doesn't have any configurations for instrument output.
Thanks,
Marcus
DP5, Imac 2.0, OSX 10.4.1
http://www.marcussjohnson.com" onclick="window.open(this.href);return false;
marcushane
Re: Miroslav Philharmonik Multi Output?
I guess I'm tweakin. 8)
Frodo
Post by Frodo »
It's possible. There are outputs for each patch which are assignable. What I'm not figuring out is what might be preventing those outputs from reaching DP's audio inputs on your system.
more soon.
marcushane
Hey Frodo,
How do you change the assignment in Miro? I'm getting 1+2 across the board and no other options. I checked the prefs and nada. At any rate I love this library and will make it work.
Frodo
Post by Frodo »
Hey marcushane:
In Miro-- the Output column is right under the bank 1-8/9-16 selector in the middle of the interface. Sorry if that oversimplifies things too much.
You can change the output assignment by click dragging the mouse upwards to get from 1+2 to 3+4 and beyond.
To assign Miro's outputs to DP's inputs, create an AUX track. In the AUX track's INPUT column, choose New Stereo Bundle. Unless I've changed the name of the Philharmonik instrument track, here's what I see listed:
Philharmonik 1 1-2
Philharmonik 1 3-4
Philharmonik 1 5-6
Philharmonik 1 7-8
and on all the way up to:
Philharmonik 1 31-32
If you are running Philharmonik in mono, it will be:
Philharmonik 1 1
Philharmonik 1 2
Philharmonik 1 3
and so on.
If you open a second stereo instance, you should see the following as AUX track input Bundle options:
Philharmonik 2 1-2
Philharmonik 2 3-4
Philharmonik 2 5-6
Philharmonik 2 7-8
and so on.
New AUX track mono Bundles will of course display mono outputs.
I would suggest including a Master Fader on all multichannel projects so that all of your ins and outs will be summed for monitoring. But as long as your AUX track outputs are assigned to the main outputs of your audio interface you should be fine.
Hope that helps.
marcushane
This is exactly what I needed Frodo. Thanks. I knew it had to be done. The Shire is proud once again.
Frodo
Post by Frodo »
marcushane wrote:This is exactly what I needed Frodo. Thanks. I knew it had to be done. The Shire is proud once again.
:lol: :lol: :lol:
